AEM CAI install
I had an AEM CAI installed a few days ago, left my buddies house and drove home, about 60km's from his place to mine. On my way home I didn't run into any problems, car ran smooth. Had the car in the garage for 2 days after and finally took her out tonight for a little spin. I let the car warm up and then drove away.
About 2 min from my place I get on a stretch of road and decide to punch it, wanting to hear vtec again. As I get higher in the RPM's about 4-5k the car starts to bog and buck, just a little though kind of sputtering, and then once in vtec it was smooth. My CEL comes on and starts flashing, then all of a sudden it's gone and doesn't return?? Should I be concerened?
I drove around for atleast another hour to see if it would return or start sputtering again but nothing. I gave it a few times after and no CEL came on.
Anyone know what might have happened?
Crossed vacuum lines would generally sustain a CEL once it comes on, but you never know. It could also be a backwards check valve, which takes a bit longer to generate a CEL and may not initially stay on (the first time). What's scary is that the CEL "flashed". This usually means a severe misfire is happening, although it was momentary. If this is the case, even with the CEL off, it may still be possible to pull the code.
Originally Posted by xviper,Aug 11 2005, 09:08 PM
Did the temp gauge reach "3 bars"? If not, you hit the cold rev limiter. If is was "really" warmed up, then suspect the MAP sensor. Honda has a TSB for this.
Originally Posted by koala,Aug 11 2005, 09:40 PM
You might also have your vacuum lines reversed. Check those, too.
Again I drove around after this light was on, and nothing ever happened.
Originally Posted by xviper,Aug 12 2005, 08:03 AM
Not necessarily. Read my last post.
Thanks for your help.
Tarcy
Originally Posted by GPW03,Aug 12 2005, 09:08 AM
Good to know. I'll check them tonight. Could you tell me where these lines are located? Im not to engine savy as you can tell.
Tarcy
Tarcy
