AEM CAI install
Originally Posted by xviper,Aug 11 2005, 09:51 PM
Crossed vacuum lines would generally sustain a CEL once it comes on, but you never know. It could also be a backwards check valve, which takes a bit longer to generate a CEL and may not initially stay on (the first time). What's scary is that the CEL "flashed". This usually means a severe misfire is happening, although it was momentary. If this is the case, even with the CEL off, it may still be possible to pull the code.
It's your vacuum lines
Originally Posted by xviper,Aug 12 2005, 08:59 AM
Could it be the MAP sensor? I hear this tends to be faulty on our cars.
However, that flashing CEL should be of some concern.
Originally Posted by xviper,Aug 12 2005, 02:44 PM
Yes, it can. Do the MAP whack and ECU reset and if this clears up the problem momentarily, then you are a candidate for the new sensor and securing system.
I guess if it happens again is where I should worry? It seems to be fine now.
Originally Posted by GPW03,Aug 12 2005, 03:01 PM
I drove the car again tonight, and it drove fine with no glitches. Was able to hit vtec, and not feel any hesitation.
Originally Posted by koala,Aug 13 2005, 11:16 AM
Based on what you just said it was probably the map sensor acting up.
Might be worth having the dealer perform the TSB on it
Originally Posted by GPW03,Aug 13 2005, 04:46 PM
I will do that. Thanks for the advice. Does everyone have the MAP defective issue? I read about it here and there but thought they were one off incidents.
It was a BIG problem on my '01. On my '04 I've only had the issue a couple of times
Originally Posted by koala,Aug 13 2005, 05:39 PM
Not everyone seems to have the issue, and sometimes its a bigger deal than others.
Tarcy
hyperpm
Dec 5, 2002 10:48 AM
