Which aftermarket clutch to go with
Alright its time to get a new clutch so I'm going to upgrade to a stage 3. Which brand does anyone suggest going with. Also I'll be turboing MY01 soon so would you go with stage 3 or stronger. Also where is a good place to get them cheap. Thanks for any help
my current setup is act hd plate, act street/strip clutch, oem bearings, toda flywheel.. the pedal feel is slightly stiffer than the oem and its holding up pretty well.. some of the midwest community guys are running spec clutch setup with the s/c and it grabs quite good. inorder to find the right clutch for your setup, you have to determine how much hp you will be pushing and what you are gonna use it for. (i.e. daily, street/strip, copitition,etc..) than you can find the right clutch for your needs.. good luck..
