Replacement clutch?
Old Sep 5, 2007 | 09:05 AM
Legal Bill's Avatar
Default Replacement clutch?
After only 25K my original clutch is starting to feel a bit weak. Too many launches at the autocross I guess. Anyway, the car is completely stock and I don't autocross too much anymore. I want a clutch that operates smoothly, but is a bit more durable. I'm just wondering if another factory clutch would be fine if I wasn't autocrossing, or if there is a good aftermarket clutch that operates smoothly and holds up better than stock. I'm not interested in any hard core racing clutch.
Please let me hear your recommendations and reasons why you like the aftermarket clutch you bought. Also, did you buy all three pieces or just a disc or disc and plate???
Thanks in advance.
Bill
Old Sep 5, 2007 | 02:46 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I would definitely get:
OEM disc
ACT pressure plate
good to do also:
OEM TO bearing and pilot bearing
For me, lightweight flywheel. you can deglaze the stock flywheel with sand paper if it's not to burnt and it will be 100% fine.
Old Sep 5, 2007 | 03:52 PM
Slows2k's Avatar
Old Sep 5, 2007 | 04:41 PM
Legal Bill's Avatar
Thanks Bill. Is there only one Act PP or do they have different models?
Old Sep 5, 2007 | 05:39 PM
Billman250's Avatar
Top Answer: 1
That is a good question.....seems there is only one type that has been sent to me in 20+ installs. The yellow one
But if you do find there are others, one above stock is preffered.
Old Sep 5, 2007 | 06:17 PM
S2KPUDDYDAD's Avatar
ACT only has the one pressure plate they use the disc to chang the clamping force.
Old Sep 5, 2007 | 07:20 PM
Legal Bill's Avatar
Interesting. Thanks.
Legal Bill
Oct 6, 2017 07:26 AM
wankun
Oct 26, 2016 01:18 PM
MrChoi
May 7, 2009 01:18 AM
Badmix
Feb 18, 2009 04:50 AM
TCS2K
Feb 13, 2008 03:40 AM
