Aftermarket Flywheel Weight
Old May 5, 2006 | 11:08 PM
REVZ TO9's Avatar
Banned
Default Aftermarket Flywheel Weight
I was thinking about getting an aftermarket flywheel. Which brands and weights are ideal for max performance?
Old May 6, 2006 | 04:00 AM
Sideways's Avatar
There are a gazillion of us running the Comptech chrome moly steel flywheel. I seem to recall it was 5 pounds less than the factory wheel. About 8+ lbs vs 13+ lbs. Correct me if wrong, it's been 4 years since I weighed it.
The Toda is similar in weight. The lightest I have seen posted (and I don''t remember which one) is around 7 lbs. All of them will give you a good driving experience with quicker engine wind-up.
Old May 6, 2006 | 05:55 AM
negcamber's Avatar
Been researching this too. Comptech and Spoon are 9.2lb...Toda is 8.4lb...Fidenza is 8lb (and aluminum...would be concerned about cracking personally). I'll probably go with the Comptech...you don't want too light of a flywheel as that does effect drivability.
Old May 6, 2006 | 10:32 PM
evoman2669's Avatar
i have the fidanza, and i believe its the lightest of the group, so far its been amazing, and i recommend it to everyone! plus, you can get them for around 300 now. They make good quality products.
Old May 6, 2006 | 10:53 PM
fillmatic's Avatar
Yup, Fidanza!
Old May 7, 2006 | 05:35 AM
musicalVTEC's Avatar
How's the driveablility with the Fidanza?
Old May 9, 2006 | 08:35 AM
evoman2669's Avatar
i think its just as easy to drive as stock... but i have been driving stick since i got my license. You may have to rev a little higher to start off (like 2k) but i think its worth it... no driveability issues here!
Old May 9, 2006 | 08:22 PM
timg's Avatar
I had a Fidanza, didn't like it, and removed it. I'm back to a stock flywheel with lightened SPEC pressure plate right now. It probably weighs as much as the Comptech and ACT combo. For a NA car, it's probably worth it. On a FI car, I can think of a LOT of better ways to spend $300.
Tim
Old May 10, 2006 | 02:09 AM
s0rted's Avatar
Been using the Spoon flywheel. Quality's excellent and the weight's just right, not too heavy not too light at 4.2 kg.
Old May 10, 2006 | 04:50 AM
energetic's Avatar
I also recommend J's Racing flywheel which is designed to gain power/torque in the whole range of the rpm's.
