Aftermarket Suspension
Old Mar 27, 2005 | 02:07 PM
Dolemike's Avatar
Thumbs up Aftermarket Suspension
Are tehre any other aftermarket options other than coilovers to replace the stock shocks? All ive seen are coilovers
Old Mar 27, 2005 | 02:37 PM
Nhan's Avatar
koni yellows
Old Mar 27, 2005 | 05:39 PM
terd ferguson's Avatar
I think Honda Modulo offers optional shocks. They may be Japan only though. I'm sure somebody like A&J Racing could get them.
Old Mar 27, 2005 | 06:47 PM
RazorV3's Avatar
koni yellow shocks are pretty much what you want/need. they will outlast your car and offer great performance. height (through perches) and rebound adjustable.
Old Mar 27, 2005 | 07:10 PM
I dream of S's Avatar
Old Mar 27, 2005 | 07:38 PM
vtecvoodoo's Avatar
I use Koni.
Old Mar 27, 2005 | 09:38 PM
afwfjustin's Avatar
I can vouch for Koni Yellows on my old Si, they were rad.
Old Mar 28, 2005 | 06:43 AM
Dolemike's Avatar
Where is the prime place to get the Koni yellows? Also do they lower the car too????? Or would that be what the aftermarket springs would do? Im assuming the Koni Yellows come with out springs, so which woulds mate well with them?
Old Mar 28, 2005 | 09:22 AM
RazorV3's Avatar
check out www.shox.com
you can use the shocks themselves to lower the car up to another 1/2" inch using the ajdustable perches (where the spring sits on the shock). you will need aftermarket springs (i highly recommend kg/mm or espelir) to really lower the car. the problem with a spring/shock combo like this is that it can make your car look uneven if you don't do your research properly. for example i'm running kg/mm race springs and the koni's. by talking to people, i knew that the rear would be lower if i didn't adjust the perches. so i put the fronts on the lower shock perch and the rears at the factory setting. the drop is almost perfect now. so make sure you ask around to see what setup works best.
Old Mar 28, 2005 | 09:45 AM
Dolemike's Avatar
Thanks razorv3 ill do that, thats the reason that Im updrating my suspension system now, because my stocks are worn out and the ride heights are off.
Chris@NLM
786
Dec 28, 2015 10:04 PM
notyourfriend
Jan 5, 2007 06:02 AM
s2k_9000rpm
Dec 24, 2006 03:33 AM
RoaringVtec
Jun 16, 2005 12:20 PM
