Aggressive downshifting
Old Jan 16, 2013 | 06:28 PM
Simplegreenvr6's Avatar
Originally Posted by lopez14
And it all makes sense now, I've always noticed its extremely difficult to get into first gear when rolling.
Old Jan 16, 2013 | 07:26 PM
Fuman's Avatar
Holy moly that is good to know, I've down shifted into first way too many times but it looks like I'll have to stop. Looks like 2nd gear is my new bestfriend now. And it all makes sense now, I've always noticed its extremely difficult to get into first gear when rolling.
And what I ment by making them "more aggressive" is downshifting at a slightly higher speed therefore when I downshift my rpm's will be higher therefore having a harder pull while in vtec. Does that make better sense? Idk maybe you guys are right and I'm just confusing lol
I get what you are trying to say.
Let me rephrase, and tell me if I got it right.
At what gear will give me the fastest acceleration if I'm at a particular speed? (e.g. 30/50/70mph)
For example, what is the optimal gear, in terms of acceleration, should I be at for 30 mph.
It's tricky to answer because at times, you'll run out of revs way too quick. An obvious example, is downshifting such that the resulting RPM is at 8000.
Perhaps a rule of thumb is for the lower gears (1,2,3) you want to be at the bottom of vtec (e.g. 5800 rpm, where vtec engages) since you'll run out of revs quickly. At higher gears, you can afford to be at a higher rpm.
Don't mind the members that are giving you crap about shifting into first. You know now, lesson learned, and move forward.
Forgive me for the following, going to go 'grandfather on you':
The key to driving fast is to drive smoothly. This also lowers the rate of wear and tear on your car.
I learned the above at track-school, and really can't disagree with what was taught.
Old Jan 16, 2013 | 10:11 PM
Johnson86's Avatar
The most agressive downshift is from 6th gear all the way to 1st gear, you should try it sometime!
You will see that your engine internals want to be agressive aswel and eventually fly around.
Best results can be found from 100+ mph!
Old Jan 16, 2013 | 10:35 PM
s2000Junky's Avatar
I'm curious to see what you guys are downshifting at on stock gearing ap1's for hard pulling, I usually do this, 30mph=1st, 50mph=2nd, 70mph=3rd. Can I make my downshifts more aggressive? (as in maybe 35mph for 1st) what's a good point without really pushing it? I don't want to downshift into redline and then have to shift up again. Anyone have any input?
Your already on the verge of pushing it, no sense in being any more "aggressive". Especially so if your tuned with vtec down sub 4k-5k rpm where you have no risk of dropping out of your poweband.
Old Jan 16, 2013 | 10:37 PM
s2000Junky's Avatar
Originally Posted by s2000maniac
you should never downshift to first...
You do realize you can do in excess of 40mph in first gear? I generally don't feel the need to downshift to first going anywhere over 20mph, but you can safely go more if you are smooth and deliberate, but there usually is no need unless there is that one damn tight corner you bog out of at the racetrack. A good tune usually resolves that issue though.
Old Jan 16, 2013 | 10:39 PM
s2000Junky's Avatar
Originally Posted by S2KIrishman
no, you should never downshift into first unless youre at a completely stop or barely rolling...good way to f@#k up your transmission
BS in this car. Learn how to operate your clutch, gas and transmission effectively and you wont have a problem.
Old Jan 17, 2013 | 04:46 AM
CoolGuy094's Avatar
I have downshifted into first at one or two autox's where there were sharp u-turn type elements. I assumed it was a little rough on the trans to do so, but it was certainly possible... like other said, just had to get the revs up.
Old Jan 17, 2013 | 04:55 AM
RedCelica's Avatar
actually, instead of being more aggressive with your downshifts, I would recommend being less aggressive after reading this thread. Smooth your transitions with a proper rev match if you're not already doing so and remember "Slow in, Fast Out."
Old Jan 17, 2013 | 04:56 AM
Old racer's Avatar
I found going back to first gear, in anything but a very low powered car counterproductive.
I did try it on a track with the slowest hairpin in Oz, but I found it induced too much wheel spin to be a fast way out of the corner, & you held the gear for such a short time it didn't work anyway.
I tried it in a Morgan +4 which had only about 150 BHP, & an F2 Brabham, with about 220, & in both instances the stop watch said it was slower.
What did work, in most cars, was a short gentle dip of the clutch, just enough to allow a couple of thousand RPM of clutch slip. This did give better acceleration, a small measurable reduction in lap times. It probably also caused little more wear than a couple of racing changes, but I did not think the tenth of a second or so gained was worth it. It just felt bad mechanical practice to me.
Old Jan 17, 2013 | 06:11 AM
takeshi's Avatar
Sounds like you need some track time with an instructor -- especially if you're relying solely on the speedo for shifting IMO.
@woodson My question makes perfect sense to me and apperently to these guys as well. So please take your English teacher self somewhere else if your just going to question my grammar.
@s2000maniac are you serious or trolling? Is downshifting into first harmful? Even if kept within limits? For example downshifting into 1st at 30mph where it puts me right at 6k rpm's
If you're asking for help you really shouldn't insult those giving you info. Granted "never downshift into first" isn't quite right but that tends to be the case with the word never. It's very rare that you'll really need to downshift into first.
^ This. You probably don't need more aggressive shifting. It can be counterproductive if you don't have a good understanding and feel for vehicle dynamics. Again, get some track time with an instructor. We really don't want your next thread to be a crash thread.
