Aggressive downshifting
Old Jan 17, 2013 | 09:34 AM
  #21
Brndon's Avatar
Originally Posted by Johnson86
Originally Posted by lopez14' timestamp='1358388311' post='22272219
Idk maybe you guys are right and I'm just confusing lol
The most agressive downshift is from 6th gear all the way to 1st gear, you should try it sometime!
You will see that your engine internals want to be agressive aswel and eventually fly around.
Best results can be found from 100+ mph!
C'mon man, this isnt honda-tech
Old Jan 17, 2013 | 10:17 AM
  #22
mazelmazelgoodthings's Avatar
Originally Posted by s2000Junky
Originally Posted by s2000maniac' timestamp='1358386388' post='22272166
you should never downshift to first...
You do realize you can do in excess of 40mph in first gear? I generally don't feel the need to downshift to first going anywhere over 20mph, but you can safely go more if you are smooth and deliberate, but there usually is no need unless there is that one damn tight corner you bog out of at the racetrack. A good tune usually resolves that issue though.
x2. I downshift to first when im pulling into parking lots and such at no more then like 10 or 15 mph when I know im going to be creeping along at slow speeds and don't want to bog down in second. car doesn't seem to have a problem with it.
Old Jan 17, 2013 | 12:39 PM
  #23
Saki GT's Avatar
Originally Posted by xviper
If you are auto-Xing, it may require downshifting in to 1st. 1st gear has a very aggressive "blocker ring" which makes it more difficult to engage on a moving downshift from higher speeds. It can be done and it usually involves a double clutch and revving the bejesus out of it. ... At lower speeds, it is possible to downshift to 1st by just revving hard to match. It's possible to beat the blocker ring if done a certain way. However, unless you're on the track, why bother?
I only shift into first if I'm at an autocross, otherwise there really is no point as 2nd is still aggressively geared, but I think that's beside the main point of this thread.
I think it was answered early on, but if you are looking to downshift for the purpose of getting to the most effective WOT acceleration, you want to downshift so you are right at the 6k mark and can take full advantage of the aggressive cam phasing. If you can't get right to 6k, you're better off over it than under it, especially with the F20.
It is important to know the max speeds you can downshift at when breaking.
Old Jan 17, 2013 | 02:56 PM
  #24
S2KIrishman's Avatar
Originally Posted by S2KIrishman' timestamp='1358387455' post='22272191
no, you should never downshift into first unless youre at a completely stop or barely rolling...good way to f@#k up your transmission
BS in this car. Learn how to operate your clutch, gas and transmission effectively and you wont have a problem.
i know how to operate my clutch, gas, and trans effectively...you can downshift into first while going faster than 10 mph all you want, i on the other hand will stick to 2nd...and i still wont have a problem
Old Jan 17, 2013 | 03:30 PM
  #25
s2000Junky's Avatar
Originally Posted by s2000Junky' timestamp='1358408388' post='22272647
[quote name='S2KIrishman' timestamp='1358387455' post='22272191']
[/quote]
Except bogging your motor
This isn't your grandfathers pick up truck lol. You can actually rev match with this car. They called that driving skill and using your equipment effectively.
Old Jan 17, 2013 | 03:56 PM
  #26
i have never been on the track or doing an event where i ever needed to down shift into first, ever...and i can rev match quite efficiently actually, but thanks for the advice
Old Jan 17, 2013 | 05:01 PM
  #27
Presto123's Avatar
Revmatching is key that is all.
OP have you been roll racing?
Old Jan 18, 2013 | 08:19 AM
  #28
Conedodger's Avatar
I've been on many 60 second courses where I've had to downshift to first at least 4 times. Autocrossed the car heavily for 8 years. Transmission shifts like new and clutch is original. Not much need to do it any other time.
wvu13
Aug 17, 2007 11:23 PM
xs2kFanaticx
Nov 7, 2006 09:26 AM
jlstyle82
Oct 9, 2003 09:11 AM
