Air filter lid off
Old Aug 25, 2017 | 08:39 AM
  #21
white98ls's Avatar
I loved the sound when I had my S. FWIW, I did a track day last year with a friend in his S2k. Same year, both stock except his had a K&N FIPK and I was alternating between lid on and lid off. We were always equally matched on the straight, whether lid on or off, and surprisingly I didn't notice a decrease in peak straight speeds with lid off either. So although I'm sure it makes less power, the difference (when not stuck in traffic) appears to be pretty minimal.
If I had kept the car longer, I would have sprung for the FIPK.
Old Aug 25, 2017 | 11:35 AM
  #22
balkolite's Avatar
I also took the lid off the first month I had my car haha. It sounded amazing, but it was also the last time I clearly heard the intake sound alone. I installed my k&n FIPK intake paired with the invidia q300 exhaust at the same time. I can only hear the exhaust now
Old Aug 26, 2017 | 12:34 PM
  #23
osu1978's Avatar
I have the comptech intake and once you use weatherstripping on the lid to fix the buzz you get the great sound and lower IAT's than stock.
Old Aug 27, 2017 | 07:35 PM
  #24
spdracerut's Avatar
I tested back to back with lid on/off. Lost about 15whp.
Project S2000: Part 20 - Stock Air Box Modifications And Not Going Faster
Old Aug 28, 2017 | 10:58 AM
  #25
white98ls's Avatar
I think on a dyno the effect is worse though. While moving there will be more air circulating in the engine bay so it is not as hot and heat-soaked. It was definitely not a 15whp difference when I was on the track and alternating between lid on/off and chasing a friend's AP1 w/FIPK.
Old Aug 28, 2017 | 11:43 AM
  #26
Saki GT's Avatar
You are absolutely correct that dynos will not be accurate because you don't have a wall of high pressure air pushing into the car. That said, a WOT intake is sucking a lot of air and with direct access to that crispy over-engine air, it will pull that in to a certain extent even while moving.
Back in the day a few of us did roll-ons on the highway and between lid on and lid off, there wasn't a noticeable change. However, the improved throttle response between either and the K&N FIPK was tremendous. The FIPK was much more immediate.
If you want some nice intake sound, the FIPK at least will give you that and better throttle response.
Old Aug 28, 2017 | 12:16 PM
  #27
Car Analogy's Avatar
I believe the 'dyno' testing in that article was based on a dyno simulator, driving the car on the road and measuring its stats, and extrapolating hp & tq. So it wasn't stagnant dyno air.
Old Aug 28, 2017 | 01:13 PM
  #28
Fokker's Avatar
It was done in real world conditions and the car saw a significant decrease to acceleration with the lid off. 3rd gear pulls from 3700-7800 increased in time by ~1.4 seconds. He used a spreadsheet calculator to determine that 15whp at the upper end and 5-10 lb/ft torque at the wheels across the ranges tested.
Old Aug 28, 2017 | 08:07 PM
  #29
arsenal's Avatar
There were so many flaws in this test. A guy putting his foot down on a country road is not an accurate test.
Old Aug 28, 2017 | 09:26 PM
  #30
spdracerut's Avatar
I used the same stretch of road, same direction 4 runs, 2 with the lid, 2 without the lid, all within 5 minutes total. If you looked at the data, the data was very repeatable with and without lid.
