Airbags
Old May 7, 2005 | 05:11 AM
Trip's Avatar
Default Airbags
What is required to be replaced, fixed or reprogrammed if the Airbags deploy in an accident ?
Old May 7, 2005 | 09:18 PM
Slows2k's Avatar
The SRS control unit, and whatever deployed compenent. Airbags, and seat belt pretensioners.
Old May 8, 2005 | 02:45 AM
Trip's Avatar
After replacing all deployed components and the SRS control module, will the new SRS control module need programming that only Honda can do ?
Or just replacing all the above, resetting the ECU and all is done ?
Honda dealer are trying to get some money out of me by telling me that they only can change them as it needs programming and special tools to replace.
Old May 8, 2005 | 06:57 AM
Slows2k's Avatar
the new unit can't be programmed. It will require tamper-proof torx bits to remove the bolts on the control unit.
Old May 8, 2005 | 10:05 AM
Trip's Avatar
What do you mean by "tamper-proof torx" ?
Old May 8, 2005 | 10:54 AM
Slows2k's Avatar
A tamper-proof torx bolt has a center pin in the middle of the star-shaped torx. A regular torx bit will not engage the bolt.
Old May 8, 2005 | 03:30 PM
Trip's Avatar
S|-||T , not a tool any garage has i guess.
Thanks for the Info SlowS2k
Old May 8, 2005 | 05:14 PM
S2k Dude's Avatar
You need a Safety Torx bit to fit that screw. Not all that uncommon, I've got a set in my desk at work. I've seen sets selling for $10 + shipping on the Internet. Just look around you find one.
Old May 27, 2005 | 04:34 PM
Trip's Avatar
Done it and all worked fine. DIY job
Thanks
macr88
Electronics
Nov 30, 2010 04:42 PM
badboy00z
May 14, 2009 03:07 PM
goldenarmz
Feb 21, 2008 05:28 PM
wanabe
Jan 26, 2008 02:27 PM
WindchaserS2K
Mar 30, 2006 10:27 PM
