Alignment help!
Old Dec 18, 2006 | 09:06 AM
IloveS's Avatar
Default Alignment help!
Hello everyone.
I want to ask everyone a question regarding the steering wheel problem. My car now has about 5500 miles on it. It is pretty much brand new. But the steering wheel has a problem. It slightly pulls the the right. So if i keep it straight as it is supposed to be, the car will pull to the right. The tire pressure is good for all. Do I need to get it aligned? Does my warrenty cover alignment? Has anyone here gotten the same problem?
Old Dec 18, 2006 | 09:15 AM
mikey k's Avatar
Could be a mismatch on front caster. I doubt you will get this on warranty. I'd get it 4 wheel aligned. I'm on my 4th S and they don't tend to come out the factory that accurate!
Old Dec 18, 2006 | 09:29 AM
IloveS's Avatar
I went to the dealership where I bought my car asking for someone there about it and he said it might not be covered. Plus, the alignment mechine is too high for the S ( I mean from ground to the bottom) so they can not drive the S over the lifter and they can't do anything with that. Then I asked have you guys ever done alignment for any S2K owner? He said NOOOOOOOO. They have ever gotten any issue like that before.
Old Dec 18, 2006 | 09:35 AM
Woodson's Avatar
Yes, get an alignment. No it's not covered under warranty.
Old Dec 18, 2006 | 10:01 AM
mikey k's Avatar
take is some where who knows what they are doing
Old Dec 18, 2006 | 10:04 AM
Woodson's Avatar
F'in dealers.
Maintaining your alignment is part of proper maintenance. At least for a sports car.
Old Dec 18, 2006 | 10:28 AM
IloveS's Avatar
Should I take my S to Pepboys? Are they good? How much do they charge for alignment?
Old Dec 18, 2006 | 10:33 AM
Woodson's Avatar
Take it to an alignment shop. Plan for around a hundred bucks give or take.
Old Dec 18, 2006 | 11:06 AM
xfer107's Avatar
If you are on stock height, why not get a warranty with an alignment, depends on your road conditions, some areas u need once or twice a year. Smooth streets maybe every 2 years+
Old Dec 18, 2006 | 11:35 AM
Markk's Avatar
Pep Boys? You're joking right?
