alignment question.......
Old May 28, 2004 | 12:16 AM
owenxguo's Avatar
Default alignment question.......
I have changed lower springs before, and I think I should do an alignment.
but the shop said because I changed the lower springs so they can not do this for me, there are some differant from stock, and they don't have data for aftermarket springs.
so what should I do???
Old May 28, 2004 | 12:43 AM
tru's Avatar
tru
take it to another shop
Old May 28, 2004 | 04:16 AM
ImportSport's Avatar
Do you want an aggressive "race" alignment or do you want a stock alignment?
If you lowered your car then you probably want some negative camber and are looking for a slightly more aggressive alignment get those values and take them to a "smarter" shop.
Old May 28, 2004 | 08:38 AM
owenxguo's Avatar
so a stock alignment will be fine right?
check this out, this is why I am thinking to do alignment, inside of the tires wear too much.....
Old May 28, 2004 | 08:42 AM
JamieS2K's Avatar
get it done asap, or your tyres will wear unevenley
I have had mine done since fitting lower springs
Old May 28, 2004 | 10:07 AM
owenxguo's Avatar
[QUOTE]Originally posted by Jamies2k
Old May 28, 2004 | 10:18 AM
mbilderback's Avatar
The stock alignment does toe-in a bit and cause uneven wear. That's natural to enhance cornering. Go with stock.
Old May 28, 2004 | 05:26 PM
owenxguo's Avatar
damn I did stock again today, feel nothing improvement.
Old May 28, 2004 | 09:44 PM
MattG's Avatar
You could try the UK alignment specs ...many peopl on this list like that setup.
Old May 29, 2004 | 03:18 AM
QIKSILVR's Avatar
Is it a common consensus that the alignment should be checked even on brand new cars since it's a strong possibility that it is out of whack from the factory?
