alignment question.......
Old May 29, 2004 | 08:13 AM
owenxguo's Avatar
that guy told me I need camper kits is that true????
Old May 29, 2004 | 08:25 AM
S2000PILOT's Avatar
No, its not true.
The camber on the S2000 can be adjusted. The guy who did my alignment adjusted the camber.
Old May 29, 2004 | 08:32 AM
owenxguo's Avatar
oh thx guys.....I think I should do it myself.....damn too much confuse......
Old May 29, 2004 | 12:06 PM
Road Rage's Avatar
[QUOTE]Originally posted by Jamies2k
get it done asap, or your tyres will wear unevenley
Old May 29, 2004 | 06:36 PM
owenxguo's Avatar
oh also any1 have some data I can use?
thx a lot.......
Old Jun 4, 2004 | 09:01 PM
TokeMadBowls420's Avatar
If you lower your car and run your car primarily on the street, all you should look at really is the camber.
The alignment settings are in your owner's manual. The inside of the front tires on the s2k usually wear out a little quicker than the outside of them (if I am correct), which is wierd considering the fronts have a -.3 degree setting. The rear tires have a -1.3 degree setting and wear evenly.
And to correct MBilderback, the stock toe in setting is for the rear only and that is just to improve rear stability in corners. And most rears on S2ks do not wear unevenly compared to the fronts.
Old Jun 4, 2004 | 09:25 PM
Kodokan_4's Avatar
Maybe the S2000 suspension guru can recommend a shop in your area:
http://forums.s2ki.com/forums/showthread.p...threadid=210519
-Pete
Old Jun 4, 2004 | 09:40 PM
Dark_Sub_Rosa's Avatar
I got the UK spec alignment...I love it! I had to search to find the exact specs and now I don't remember exactly what they are.... I know its -2 camber in the back but the caster and toe I forget. I think its 20 degrees toe maybe?
tlegend
May 1, 2006 10:03 PM
CyBerNeo
May 24, 2005 02:50 PM
owenxguo
Apr 1, 2004 05:37 PM
Mok
Mar 13, 2004 11:26 AM
TampaS2k
May 23, 2002 04:32 AM
