alignment question
Old Apr 14, 2008 | 05:24 PM
tien2's Avatar
Default alignment question
I just recently lowered my car a little over an inch (barely fit two fingers between tire and fenderwell) on stock wheels and tires. My questions is with my ride height would I be able to get it to factory specs or almost near it (camber, toe, and caster wise) when I get an alignment. Thanks.
-tien
Old Apr 14, 2008 | 06:10 PM
mlc's Avatar
mlc
You should be able to. I don't know where you are but I would post up in your region and find a good alignment shop.
Do you know if you want to put the UK specs in the car?
Do a search on here about alignment specs and I would bring the specs with you and tell them that is the alignment you want in the car.
Defiantly get a before and after sheet from them.
mlc
Old Apr 14, 2008 | 06:11 PM
03silver2000's Avatar
yah you can get in factory specs i have my car lowered on espelir springs with stock wheels and im in factory specs.
p.s im a mechanic and do alignments
Old Apr 14, 2008 | 06:12 PM
tien2's Avatar
if you lower your car about that low whats the max negative camber in rear you can get is it between -1.7 to -2.7. Thanks for the help you guys, I really appreciate it.
Old Apr 14, 2008 | 07:24 PM
vtec9's Avatar
No problem whatsoever. I'm lower, and I didn't have a problem. All my specs are literally dead center of the recommended.
Old Apr 14, 2008 | 07:43 PM
RED MX5's Avatar
Same here. When adjusted to UK specs I have adjustment range to spare.
First alignment after a drop can be tough, so if possible have it done by someone who is willing to put in the time to do the job right.
Old Apr 14, 2008 | 08:28 PM
vtec9's Avatar
[QUOTE=RED MX5,Apr 14 2008, 11:43 PM] First alignment after a drop can be tough, so if possible have it done by someone who is willing to put in the time to do the job right.
inlinepro1
Jun 7, 2006 10:19 AM
johnny c
Jul 13, 2005 11:04 AM
Maveric
Jun 29, 2005 02:28 PM
bobmcq11
Jun 21, 2004 12:18 PM
JT-KGY
Nov 10, 2003 02:59 AM
