alignment question
Old Jan 11, 2010 | 01:46 AM
dyhppy's Avatar
Default alignment question
dont know much about this stuff, but im wondering if these 2 alignment specs would make a noticeable difference when driving:
initial: final:
front
caster: 5.8 / 6.2 6.0 / 6.2
camber: -.9 / -1.0 -.9 / -.9
toe: -.25 / .2 / -.05 total 0 / 0 / 0 total
rear
camber -1.8 / -2.0 -1.9 / -1.9
toes .35 / .2 / .55 total .2 / .2 / .4 total
thnx
Old Jan 11, 2010 | 08:11 AM
macr88's Avatar
They should. The first one might make the car pull to one side unless you're driving on a crowned rd. It's an interesting alignment for sure.
Old Jan 11, 2010 | 08:55 AM
Saki GT's Avatar
That toe is way off front and back - was this what you had before an alignment?
Old Jan 11, 2010 | 03:15 PM
dyhppy's Avatar
those are before and after numbers. can someone explain the toe stuff? it's the direction the wheel is pointing?
Old Jan 11, 2010 | 03:16 PM
CKit's Avatar
HOLY CRAP!!!! Where have you been, bro?!!!!!!
Old Jan 11, 2010 | 03:26 PM
macr88's Avatar
Toe should be equal side to side.
-.10 means that the front of the wheel is pointing away from the centerline of the vehicle.
.10 means the the front of the tire is pointing towards the centerline.
Hope this helps.
Old Jan 11, 2010 | 04:40 PM
dyhppy's Avatar
thanks, so it ought to 0, ideally. is the rear ok, then being .2 / .2 / .4 total?
Ckit, just got tired of the negativity being directed my way. how's it goin?
Old Jan 11, 2010 | 05:07 PM
macr88's Avatar
the front at 0 is fine and if you would go any direction it would be in the negative direction for better turn in.
the rear at .2 both sides is fine and it'll provide better straight line stability but it is at the high end of the limit, the acceptable range is .06 to .22
I run my rear toe at .08
Old Jan 11, 2010 | 06:27 PM
CKit's Avatar
Toe wears tires, too.
Old Jan 11, 2010 | 07:05 PM
macr88's Avatar
more than any other adjustment
blasphemy101
Jul 12, 2011 09:05 AM
SPLNDID
Mar 14, 2010 02:19 PM
bloodzombie
Aug 6, 2009 03:43 AM
Spa4eva
54
Apr 8, 2006 09:45 AM
CrazyPhuD
May 23, 2004 04:35 AM
