Anyone know how to fix this?
Old Feb 6, 2004 | 09:38 AM
kkyntmoon's Avatar
Hey guys,
Ever since I had the car the cig lighter was like this, But I realized like 2-3 days after I had it home. I'd like to fix it myself, Rather then some honda tech messing with my interior. It seems like it should screw into something right? I don't know...
EDIT: I took out the cig lighter to show everyone. I can put it back in if i wanted to but It will just come out.
here take a look...
btw here is my baby, bravin the cold weather of ny in the cave
and here is what it looks like outside, hail/snow/rain blah.
Thanks guy/gals
Old Feb 6, 2004 | 09:43 AM
heffergm's Avatar
I'm confused. Can't you just push the assembly back in?
Old Feb 6, 2004 | 09:48 AM
kkyntmoon's Avatar
lol, Obviously,
I could push it back in. But it doesn't stay, It rattles and will just pull out if you try to.
I took it out so everyone could see what I'm talking about
Old Feb 6, 2004 | 09:57 AM
Hockey's Avatar
I know I saw a post like this already. See if I can find it..........
Old Feb 6, 2004 | 09:59 AM
Hockey's Avatar
Loose Outlet DIY
See if that link works.
Old Feb 6, 2004 | 10:15 AM
fltsfshr's Avatar
Here's what you have to do
remove the lower door sill panels on both sides.
remove the rear lower and upper panels in the back They overlap there's a couple screws, you don't need to remove the boot clip. then loosen your console cover hteres screws under there. Then the screws in the glove box and the secret compartment.
With all that off or loose (great time to clean it and it's easy to do) just gently lift on the rear console reach under and screw it back tight there's a ring there that screws on it that may be inside.
If you find you have to completely remove the rear console, you have to take off the two plastic trim pieces in the back they snap on. but you shouldn't need too.
Be sure and check you connections etc before you put it back together.. The whole thing will take you a bit over an hour.
fltsfshr
Old Feb 6, 2004 | 10:18 AM
PLYRS 3's Avatar
wow, that's quite involved.....
no wonder my dealer wanted 2 hours labour to fix it (car was out of warranty).
i passed and just left it.....
Old Feb 6, 2004 | 10:33 AM
fltsfshr's Avatar
Actually it's very easy just a couple screws everything else just snaps on and off.
sounds complicated but it's not
fltsfshr
Old Feb 6, 2004 | 10:41 AM
fltsfshr's Avatar
fltsfshr
Old Feb 6, 2004 | 11:19 AM
kkyntmoon's Avatar
thanks for the replys, I will do try this ASAP.
raymo19
Nov 2, 2012 06:18 AM
Brownergy
Feb 14, 2010 05:47 PM
essi1553
Feb 8, 2010 06:24 PM
speedfreak
Feb 13, 2003 02:22 PM
Ludedude
Jan 12, 2003 03:39 PM
