Anything to modify faux front vents?
I'm just throwing this out there for the sake of argument, I have no proof/facts one way or the other...would it be wise to place a course wire mesh along the back of the air duct to prevent large objects (i.e., rocks) from being directly introduced onto the rotor?
I'm sure rocks bounce in there all of the time, but do they have a direct line to the rotor if the duct wasn't there? Nothing too close knit that would cut down the air flow, say about 1/4" wire mesh?
The vent on the splash plate is slotted openings effectively forming a grill. The duct takes an uphill path with a pretty tight turn to stay inside of wheel travel so it is not an easy path for a object to travel. I did consider a mesh but decided in the end it was not needed. I will report if I find otherwise.
I found some aluminum connectors that are designed for something else (some sort of drain) that bolted to the plate over the vents. This gives me a place to secure the tubing so the air is directed into the eye to the rotor.
Originally posted by shaner:
I'll be cutting out my "faux grills" and will be using them as dual cold-air intakes
[QUOTE]Originally posted by swiss2k:
[B]here is mine "ram-air-intake"...
the aibox... normaly closed (original intake is closed too)
That's a pretty good job, but not exactly what I had in mind with my previous post... I'm going to use the two cavities below the headlights as conical filter boxes with cut out ducts as the cold air source (the filters will be above the ducts so water doesn't saturate the filters... I'll start as soon as I receive the aluminum tubing and get a pipe bender...
