AP2 CLUTCH IN AP1
Old Mar 29, 2006 | 05:46 PM
METATRON's Avatar
Default AP2 CLUTCH IN AP1
Can you use an AP2 clutch and flywheel in an AP1? I'm not sure. Anybody know?
Old Mar 29, 2006 | 06:09 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Complete with the clutch delay???Why???
Old Mar 30, 2006 | 10:22 AM
METATRON's Avatar
clutch delay?
Old Mar 30, 2006 | 10:29 AM
viK's Avatar
viK
Ap2 have a clutch delay, but can be removed.
Old Mar 30, 2006 | 10:50 AM
METATRON's Avatar
What exactly is the clutch delay? And if it is something not wanted, how do I remove it?
Old Mar 30, 2006 | 11:19 AM
Elistan's Avatar
The pressure plate and friction disk have the same part numbers, 22300-PCX-015 and 22200-PCX-055.
The flywheel has a different part number, 22100-PZX-005 for AP2 and 22100-PCX-005 for AP1. I suspect they're interchangeable.
The clutch delay valve is part of the slave cylinder, not the clutch assembly proper.
Old Mar 30, 2006 | 11:25 AM
METATRON's Avatar
So I don't even need to worry about the clutch delay then? I was planning on getting a lightweight flywheel anyways.
Old Mar 30, 2006 | 11:26 AM
vtec9's Avatar
the clutch delay valve is in the slave cylinder. it forces the clutch to engage the flywheel at a constant rate regardless of how fast the clutch pedal is released. Basically for a seasoned driver, it does nothing but slow you down!
Old Mar 31, 2006 | 07:20 PM
METATRON's Avatar
Well if the plate and disk are the same parts on both AP1's and AP2's. And I use, say a Toda flywheel. Everything is good then.
Black Betty
Nov 14, 2008 07:41 AM
Loves to Speed
Oct 15, 2008 05:30 PM
Ks320
Aug 30, 2008 03:01 PM
buyos1717
Aug 25, 2008 05:40 AM
damsas
Apr 7, 2006 06:24 AM
