AP2 VTEC Engagement Point
Old Feb 20, 2009 | 09:50 PM
Artric's Avatar
Default AP2 VTEC Engagement Point
What is the engagement point for VTEC for the AP2 motors?
Also, have people played around and found if an earlier engagement point is generally better on a stock motor?
What's the easiest way to shift the engagement point on an S2000? Do you need a VAFC, or a Hondata chip?
Old Feb 20, 2009 | 09:52 PM
SoMe0nE2tAlK2's Avatar
Used emanage to try to lower VTEC engagement. Got it down to 5500. Anything below that and the engine throws a CEL and goes into limp mode.
Reflash on 06+ will lower it succesfully to 4000.
Old Feb 20, 2009 | 11:22 PM
DDonovan's Avatar
Stock is 6K I believe. That is about when mine kicks in.
Old Feb 21, 2009 | 09:08 AM
Bliss@5200's Avatar
Vtec is at 6k on a stock ecu
Old Feb 21, 2009 | 09:34 AM
s2kswe's Avatar
I had trouble with my main circuitboard alternator so my vtec was at 10krpm. Was not fun I tell you.
Old Feb 21, 2009 | 09:37 AM
Saki GT's Avatar
Stock is actually about 5800 rpm - dropping to 5500 rpm seems best as it keeps the car fully in VTEC on WOT shifts. There's no point in dropping VTEC too low though - it is only effective at higher rpms - that's the whole point of it.
Old Feb 21, 2009 | 09:39 AM
Bliss@5200's Avatar
.... soo did you just not have Vtec at all then?
Old Feb 21, 2009 | 09:45 AM
s2kswe's Avatar
No it was no problem i just had to rev to 11000 but ofcourse had to bypass the secondary dash conductor cord to do this.
Old Feb 21, 2009 | 01:46 PM
Bliss@5200's Avatar
Really you rev your F22 all the way to 11K thats insane.
Old Feb 21, 2009 | 02:19 PM
mugenrsx's Avatar
5.8k-ish sounds right. Look at AP2 dynos, VTEC hits a hair before 6k.
