Bad TCT?
Old Apr 26, 2025 | 01:51 PM
DarkHorse2K1's Avatar
Default Bad TCT?
Hi, does my F20C sound good? Car was warm and it has 78000 miles. Just got AP2 retainers and keepers and valve adjustment. TCT is OEM and i don't know if it has been replaced in the past. Thanks in advance!
https://youtube.com/shorts/DQGdAXLw7NY?si=Q0fsy83umsg0DA4X
Old Apr 28, 2025 | 08:13 AM
simoncsays's Avatar
Might as replace it with a Billman TCT to rule it out and even if it's not, you don't have to worry about the TCT being a problem ever again.
Old Apr 30, 2025 | 05:48 AM
Car Analogy's Avatar
Its probably not tct at that low a mileage. But agree, you'll need to replace it at some point, and billman tct is unequaled. Lifetime guarantee. So no downside to replacing early.
In fact, replacing before there is an issue will result in less chain and related cam timing system wear (guides,etc). So its good to replace it early.
Normally I'd suggest maybe its a bit too early at your miles, but since it'd help rule something out, its a reasonable approach.
But I must also add, if you post a video taken from a few feet in front of car, hood closed, engine fully warm, idle, Billman can tell you if your noise is tct or not.
cuonice
Nov 15, 2018 08:29 AM
Sharps SSS
May 6, 2014 07:58 AM
justind
Jun 4, 2013 11:43 AM
Billman250
13
Jun 18, 2008 04:38 PM
s2k dre
Aug 21, 2007 03:39 PM
