Belt problem?
Old Sep 7, 2004 | 06:19 AM
Ajjra's Avatar
Default Belt problem?
I have a Squeaking noise on acceleration that is coming from the front of the car (sounds like the passanger side close to the engine)
Could this be a belt issue? Any suggestions if not? I have checked as much as I can that nothing is loose and it is not a rattle.
Thank you
Old Sep 7, 2004 | 09:38 AM
Dinnyin's Avatar
is it a "sqeaking" or more of a "ringing" noise?
Old Sep 7, 2004 | 10:10 AM
Ajjra's Avatar
I guess you could call it a ringing, I'm bad at this stuff. It is consistant on acceleration and it sounds just like the sound other cars make when they are out of power steering fluid, albeit clearly that is not it.
Old Sep 7, 2004 | 11:22 AM
rworne's Avatar
I get a single squeal when the engine is either idling or under load and the AC compressor kicks on. There's also a ringing noise between 3500-4500RPM under acceleration. The ringing has been gone for quite a while, but right after my dealer oil change, it's back with a vengance.
Before you all ask: Yes, I double checked their work and it's been done properly. One thing I did notice is that they filled that sucker all the way up to the top line of the dipstick. I'll let the level drop a tad and see if it goes away. Considering how my car goes through oil, that won't be very long.
Old Sep 7, 2004 | 11:26 AM
Ajjra's Avatar
I'll check my oil level. Any other ideas?
Peeves
Oct 17, 2015 08:46 AM
gambit-irl
Feb 2, 2014 08:26 AM
SOL1D
Feb 16, 2011 11:42 AM
folex187
May 7, 2004 10:45 AM
WtbS2k
Apr 24, 2004 11:04 AM
