Has anyone experienced this noise?
Since S2ki helped me to diagnose a tired tct which I am forever thankful for, I'm hoping someone on here will have heard this noise and have some idea what's causing it.
https://youtu.be/KbUveAbEl34
I have taken it to a garage and they changed the aux belt but that didn't stop it.
Edits:
The noise doesn't happen until a few seconds after engine switch on, I'll try and get a video example
The noise doesn't change by switching AC on and off
The noise isn't affected by engine revs, it stays the same
Edits:
It something driven by that aux belt... I had a similar sound and it was my AC compressor. The general advice is to take a screwdriver and put it against each component and put the that you hold up against your ear, as if it is a stethoscope. You may even just be able to touch the component with your hand and feel a difference in the vibration as the noise goes on and off.
Oh, one thing that might help to pin point the noise. When I start the engine the noise isn't there until there's a click and a quiet high pitch "whee". Whats belt driven that takes a few seconds to kick in?
I agree with Soviet, the clicking noise you refer to is most likely the AC clutch kicking in, try with the AC turned off and se if it still does it.
It could be either. It's such an inconsistent sound that I thought it had to be electrical but in person it could be either. The sound in the video is really accurate.
Pinchy
25
Feb 11, 2009 02:08 PM
