Best price for Ohlins coilovers
Hi guys,
I was originally going to go with BC racing coilovers with Swift springs for my AP1...but I think I'll just go with the Ohlins and be done with it.
What is the best price on these and site to purchase from?
Not sure if this is the best price, but I got quoted around $2,650 because I opted to buy 4 Swift 10k Springs on top of the whole kit. Would have been a bit below $2500 if I didn't want the Swift springs and just took the springs it came with instead. But that is like 2 years ago and my Ohlins DFV is the older version.
Standard MI21 kit should be 2,100 but can creep up to like 2500+ depending on options and upgrades. From what Ive seen the base kit price is the same pretty much everywhere(personally I bought mine direct from Ohlins)
you're not going to find any real deals on Ohlins...Urge Design or Sakebomb....You might contact direct and see if they can offer you any off the listed price. Patrick offered 10% for the end of the year, probably not in effect now, but worth a shot.
I went with Patrick at Urge and he was quite helpful and upgraded to Swift springs. You can't go wrong with Ohlins....other brands are second tier...Look on the Urge site for reviews of the suspension...should be info there on what you'd like to achieve, be it street or track.
Received 1,302 Likes
Be done with what, though?
There are a ton of iterations for this kit. What you're trying to do is an important piece of info.
The Ohlins dampers are great...and obviously, that's what makes up a majority of the price.
The dampers are a given...but the configuration that you mate them to will make or break the setup.
I thought the off the shelf Ohlins were good. But they didn't meet my needs. Meeting my needs took a bit more expenditure (in MY case).
So...what are u trying to be done with?
Maybe lower 1/2"-1". Carve up a back road or carve up a track. I'm not looking to do anything wild or crazy, we don't have a ton of access to tracks here, so I'd have to travel. I just want something good for the street or track that's not going to bounce all over the place or be overly harsh.
Oh ok. An off the shelf Ohlins kit will work just fine then, eh.
I wouldn't bother with swift springs or custom lower cups or anything. The OTS kit will support a 0.5 to 1" drop with enough preload to keep it comfy.
SBG and Urge and THMotorsports are S2ki vendors that carry Ohlins. Give them a call and see what options they have for you.
Good luck.
Good luck.
