Best soft top patches?
I've got the normal wear spots on my top and they let a little light through but no water through yet. I wanted to get 2 patches to cover them but wasn't sure exactly what to purchase. I've tried doing searches on here but for some reason I can't get anything. Let me know what you guys used please. I've seen this on a threat but not sure if I should get it or not. Thanks in advance guys and gals!
http://www.sportsmanswarehouse.com/s...0131/cat101548
The patches from that kit won't work. They're way too thin and extremely flexible. The aquaseal would work well as glue, but you need convertible top vinyl to make the patches. Look for someone selling patches cut out of an old top in the for sale forum, or try to find a local upholstery shop and see if they have convertible top fabric.
Before I just use tenacious tape
Then I got the idea from a member of using auto goop to seal off the tear first and then applying the tenacious tape
Holds strong (-40 to 60 degree celsius) and water doesn't leak in
Give that a try maybe?
Years ago I added extra layers to the inside of my top where the pressure points are
You will not have enough rubbing alcohol in the tiny packets supplied that's the only drawback of this stuff
If you follow the instructions the stuff sticks awesome, I just bought a bottle of rubbing alcohol so I could make sure I really got the top clean before I applied the patches
On the two worst spots I put down 2 layers, about a 2" square 1st, then a week later about a 4" square over the top
TEAR-AID® Type B is for VINYL repairs
http://www.tear-aid.com/
i messed around trying to do patches but when i eventually got big tears (i was top up/down four times day when i was in florida) i just said f--- it and just did black gorilla tape on both sides. it works, but eventually it'll come off and there is pita glue residue to mess with. i later just sprung for a hardtop (for $600 more than a replacement soft top's cost) 'cause my habits would've worn out a new top in a year anyways.
