Best spring for ride quality. No more than 1" drop.
Old Jul 9, 2003 | 02:35 PM
Brutewes's Avatar
Default Best spring for ride quality. No more than 1" drop.
Been doing a lot of reading about springs. Just thought I'd ask what people thought was the best spring for ride quality. I'm not worried about handling and taking 90 degree turns at 60mph. I don't drive it like that, and I don't autoX it. I'm thinking either Eibach Prokit or KG/MM SuperSport at the moment. I have 18" wheels. Thoughts?
Also, does lowering void any warranty? And are the KG/MM SuperSport springs progressive rate?
Thanks!
Old Jul 9, 2003 | 03:06 PM
wanabe's Avatar
eibachs should do the trick... about 1" drop with similar to stock ride.
i assume that your wheels are not rubbing now and that you have correct offsets, etc.
Old Jul 9, 2003 | 03:50 PM
rolotomasu's Avatar
I've got the KG/MM racing springs which are ~1.5". The supersports should drop you ~0.6"-0.7". Good luck.
LudeAtic
Apr 5, 2006 02:19 PM
TrIcKeD_oUt_s2K
Oct 23, 2003 08:12 AM
9K
Jul 28, 2003 12:52 PM
kush only
Jun 13, 2003 08:57 AM
dp2580
Jan 18, 2003 01:10 PM
