Best VTEC Controller?
Old Nov 7, 2003 | 06:24 AM
dayves2k's Avatar
Default Best VTEC Controller?
Thinking of getting a VTEC Controller.....Apexi(what model), Power Enterprise, JDM or any other brand I have not yet heard of..........thanks
Old Nov 7, 2003 | 06:37 AM
gerryk's Avatar
Whats a vtec controller?
Old Nov 7, 2003 | 06:41 AM
dayves2k's Avatar
VTEC shifting points can be controlled every 100rpm scale between 3000rpm and 7000rpm.
Fuel setting can be done at 8 different rpm points for low cam and high cam independently.
The system can be used for the latest i-VTEC engines as well as the standard VTEC engines.
Old Nov 7, 2003 | 06:47 AM
dayves2k's Avatar
Apexi has one that introduces the first digital fuel computer that combines fuel computer functions with a VTEC engagement controller. The V-AFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. The Fuel Adjustment function considers wide/narrow throttle and low/high camshaft settings, from which four different fuel maps are created (wide-low, wide-high, narrow-low, narrow-high). The integrated VTEC Controller adjusts the point at which the engine switches from the Lo to Hi cam during acceleration, as well as when the engine switches from the Hi to Lo cam during deceleration.
Old Nov 7, 2003 | 06:54 AM
dayves2k's Avatar
.......getting the Apexi V-AFC
Old Nov 7, 2003 | 10:57 AM
Kwando's Avatar
I have a VAFC if you want to check it out. I'm also located in CO.
Old Nov 7, 2003 | 11:01 AM
dayves2k's Avatar
~ will PM ya Kwando
Aug 23, 2013 11:46 AM
06Estukay
May 4, 2012 06:28 AM
mikeabtin
Jun 28, 2009 05:56 PM
blxmjx
Jun 9, 2003 10:02 AM
dbkelly
Feb 23, 2001 09:29 AM
