Beware of scratching your Cusco bars
Old Aug 10, 2004 | 06:24 AM
Hitman's Avatar
Arrow Beware of scratching your Cusco bars
Here's a shot of my 3-piece sub-frame Cusco bars:
I had a slight incident where a patch of loose gravel and dirt came into contact with my car (okay, so I went off-track). Obviously, the blue finish got scratched and within a month rust developed as you see in the picture.
Although my case is rather extreme, this does raise concerns for the random small rocks on the average road that can kick-up and hit/scratch the finish. So just a heads up: the pretty blue looks good on a roll-bar but will it last beneath a car? We'll see as more owners log more miles with these bars.
Old Aug 10, 2004 | 06:59 AM
Ztec's Avatar
Looks like the Bar acted like a skid plate saving the underside from some damage !
If you haven't already I would treat the rusted area with Ospho, if you know what this stuff is I appologize if you don't read on !
I use this stuff everywhere I find rust and it really works and is used in the Marine industry to keep metals from rusting. I even put it on my hubs carefully and my rotor hats to keep them from rusting.
here is a blurb from the web-site
RUSTED METALS - OSPHO is a rust-inhibiting coating - NOT A PAINT You do not have to remove tight rust. Merely remove loose paint and rust scale, dirt, oil, grease and other accumulations with a wire brush - apply a coat of OSPHO as it comes in the container - let dry overnight, then apply whatever paint system you desire. When applied to rusted surfaces, OSPHO causes iron oxide (rust) to chemically change to iron phosphate - an inert, hard substance that turns the metal black. Where rust is exceedingly heavy, two coats of OSPHO may be necessary to thoroughly penetrate and blacken the surface to be painted. A dry, powdery, grayish-white surface usually develops; this is normal - brush off any loose powder before paint application.
Old Aug 10, 2004 | 10:25 AM
freq's Avatar
Rust-Mort.
Rust Mortifier.
Worked awesome on my '84 Jeep CJ-7.
Old Aug 10, 2004 | 12:58 PM
AP1ByDesign's Avatar
Thanks for the info.
I'll go pick up some OSPHO
Old Aug 10, 2004 | 01:48 PM
dut's Avatar
dut
- im going to install mine soon and im dumped on the ground, I guess my shit will be scratched pretty quick
Old Aug 10, 2004 | 02:11 PM
jsc2K's Avatar
thanks for the heads up!
Old Aug 10, 2004 | 11:34 PM
Hitman's Avatar
Thanks nzaizar and freq. I'm looking into those products.
razzele
Dec 9, 2009 08:28 AM
kutsujula
Dec 28, 2007 10:22 AM
o2s2ooo
Nov 9, 2006 09:12 AM
S2000GT
Aug 11, 2005 02:11 PM
BlueS2000Boy
Feb 11, 2004 12:29 PM
