Big clouds of blue smoke
Originally posted by Pepe:
Spoon has a racing crankcase cover that should help in this department.
I don't know exactly but it could feature a windage(sp?) tray to help control oil splash around in high g situations. Larger oil capacity can also be part of the deal.
Rossi, Thanks for the good info on Porsche sumps. Wow, I did not realize Boxsters et al do not have dry sump lube!
Also, forgot how much oil I had to use to fill the '86 turbo I had. I remember overfilling and getting that smoke on startup at times from the oil getting into the horizontally opposed cylinders.
I was getting smoke in turn 2 at Sears Point yesterday. Turn 2 is a righthand corner, uphill with very light braking and a downshift, turn in under light, feeding throttle, cresting the hill at the apex at full throttle. I drove about 80 miles, 40 laps and lost about a quart of oil.
I don't think the problem is due to overfill, because I let the level drop and the smoke continued.
I spoke with the Scott at King about this and he agreed with cdelena - the oil apparently can't drain fast enough and gets sucked into the intake.
I first encountered this in April of 2000 with my '00 silverstone at NHIS (New Hampshire) Turn 3 - a sharp 35 mph hairpin almost... It's normal according to the Honda engineers - depends on instaneous G's.
