bought a VAFC Hardness is this normal
Actually, I just took a look at your picture in it's full size, the pin that the wire connects too looks like it's still attached to the plug, you could pull the shrink tube off the lead, stip the wire and resolder it to the pin and shrink tube it back. You probably won't have any troubles if you do that as long as you're good at soldering.
Anytime. If you can't handle the soldering, you could probably find someone around town that could do it. As long as that pin is still in once piece you may be ok. Not sure what your resources are in Madrid.
You should contact the seller though and ask for a refund of the repair costs. If he has trouble with that, direct him to this thread and we can all talk to him/her.
Damn I just installed a harness 2 weeks ago for another member and don't remember and loose cables. PM TriaXenginE (Allen) maybe he'll take a look for you since I just put it in for him.
Originally posted by S2000_Europe
the seller told again that is normal.....
does anybody has a picture of a new VAFC Harness
Here's what you could do. Hook it all up and throw a CEL. Then you can pull the DTC code and it will most likely be a P0325 Knock Sensor 1 Circuit Electrical Fault in Circuit.
Personally, I wouldn't wait for that.
HotDamnitsDavid
Jul 20, 2010 08:14 PM
mustangkiller01
Jun 12, 2004 07:20 AM
S2KEvolution
Oct 7, 2003 08:50 AM
