Brake Fluid
Old Dec 26, 2005 | 02:42 PM
WyattH's Avatar
Default Brake Fluid
I will be bleeding my new BBK tonight after install and want to use the best fluids. What is the best? I forget the name - Green Stuff? Redline? ATE Blue? I forget!
Please let me know. Thanks a lot!
Old Dec 26, 2005 | 03:11 PM
ruexp67's Avatar
What is your use? Are you going to be tracking your car?
If you are going to track then you need a DOT4 fluid. I like ATE Superblue. Others like Motul 600.
For street only use a DOT3 fluid is far more appropriate as it is less hydroscopic (water absorbing.) Any decent name brand fluid is more than up to the task for street driving. I like the Valvoline stuff.
Old Dec 26, 2005 | 06:00 PM
WyattH's Avatar
Went around looking for ATE Superblue... Couldnt find it.
I ended up buying Valvoline synthetic? Says it exceeds DOT3 and 4... :???:
Old Dec 26, 2005 | 06:18 PM
ruexp67's Avatar
Yeah, that's the stuff.
The ATE would only be available from a race shop and you would need to flush it out more often (at least anually.) It also runs about 10x the cost of regular DOT3.
Old Dec 26, 2005 | 08:00 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Changed mine last fall,and used Valvoline DOT 3-4;good enough for street driven vehicule.!!!
S2kRally
Apr 2, 2010 07:02 PM
myflys2k
May 25, 2009 06:44 PM
trivium
Sep 22, 2006 03:39 PM
anthonys2k
Sep 3, 2006 10:26 AM
midnightmethane
May 15, 2006 11:16 PM
