Brakes
Old Aug 1, 2007 | 04:42 AM
S2KNJ's Avatar
Default Brakes
Just noticed the pedal doesn't engage the brakes in the same place, it
Old Aug 1, 2007 | 05:18 AM
MikeyCB's Avatar
After 2 days on the track it's almost definitely a pad issue. Swap out the pads! Might try changing the brake fluid if it hasn't been done in a while either.
Heh heh I read the post and was thinking you put all the pieces together already!
Old Aug 1, 2007 | 05:43 AM
S2KNJ's Avatar
yeah i figured as much... i have pads and heard this is pretty easy, anyone know where there is a "how to" section on this? With pictures since i'm a dope?
Old Aug 1, 2007 | 06:19 AM
glagola1's Avatar
Your fluid has be cooked. Flush the fluid and then see if the pads are dead. It's possible that your pads have glazed but your description of the symptoms point directely to fluid with air in it.
FLUSH BRAKE FLUID first. If you just replace the pads, I can garentee your brakes will not work like they did before.
I hope I made myself clear.
Old Aug 1, 2007 | 06:41 AM
S2KNJ's Avatar
it's an '03 with 50K, fluid has never been replaced, guess it may be time?
Old Aug 1, 2007 | 10:17 AM
brykel's Avatar
If you're putting the car on the track, you should absolutely change it out with a hi-temp fluid like ATE Super Blue each season and bleed the brakes after every track day. Speedbleeders make it easy.
Old Aug 2, 2007 | 10:55 AM
minboost's Avatar
Fluid should be changed every two years (normal use), regardless of mileage (or something like that).
Anyway, if you went to the track, you should change it out.
I prefer Motul 600. Works decent on the track too.
winter5470
Feb 20, 2015 12:25 PM
gtg749m
Apr 13, 2009 08:38 PM
Legal Bill
Mar 4, 2008 06:28 PM
jal3lee
Aug 24, 2005 11:19 AM
Hitman
Feb 3, 2004 09:32 AM
