Break In Period and Oil Consumption
Old Apr 22, 2002 | 07:50 AM
FormerH22a4's Avatar
Default Break In Period and Oil Consumption
I am just curious as to everyones' oil consumption for the break in period of 600miles or 1000kms. I've just passed that mark and was down XXX.
Old Apr 22, 2002 | 08:01 AM
Gymniac's Avatar
Just over 2000 miles and at XXX (measured when hot). But noticed one notch gone in a matter of few days even though I don't VTEC much and still babying my car. I guess S2000 does have a big appetite for oil?
Also, I would think measuring the oil level when hot should give a more "accurate" indication of what's going on inside the engine as opposed to measuring it the first thing in the morning when the engine is cold?
Old Apr 22, 2002 | 08:25 AM
matrix's Avatar
My S2000 has about 2200km on it an I am down about XXX on it. I think it is better to measure the oil level cold. This way all the oil is the in pan not all over the engine so you get a more accurate reading. Tranny fluid should be measured hot.
BTW...does anyone know how much a single X translates to? Is 1 X = 1/4 litre or quart?
Old Apr 22, 2002 | 08:38 AM
xviper's Avatar
Always check oil when the engine's cold, preferably before the first start of the day. The total area within all the X's = 1 liter so divide by the X's to find out how much 1 X is.
Old Apr 22, 2002 | 08:52 AM
Triple-H's Avatar
I'm up to about 1,100 miles (1,770km) and my car when checked cold is down about 1 X. My breakin was mild and no VTEC until over the specified 600 miles. I have run the car for long periods of time as opposed to lots of short trips and I'm VTECing on a regular basis now. I have been very pleased.
Old Apr 22, 2002 | 11:07 AM
intendedaccel's Avatar
I have just under 3 thousand miles on my car now and it has used about a 1/3rd of a quart most of which was in the first thousand miles. It doesn't seem to be using any now.
Old Apr 22, 2002 | 11:11 AM
mjcohen's Avatar
My S2000 burned lots of oil until about 5500 miles. Every time I have checked since then, it hasn't moved from the top H
I still check every time I fill up the gas tank though, just in case.
Old Apr 22, 2002 | 03:03 PM
RIDGERCR's Avatar
Went down 2 "X"s in about 850 miles. Hit VTEC almost a dozen times since after the 600 mile mark. Still checking the oil at every fuel fill-up.
-RIDGERCR
Old Apr 22, 2002 | 06:04 PM
Destiny2002's Avatar
Over 400 miles and still on the full line
Old Apr 23, 2002 | 03:53 AM
Gymniac's Avatar
OK, I checked this morning (when it was COLD) twice. And it's down to only 1 notch above L ! I guess that means I have to fill it up? But with which oil? Honda has a special "break in" oil, correct? Should I be using this or "regular" engine oil from Honda? Any tips on How-to of filling in the engine oil (I'm afraid of overfilling)? Or should I leave it to a Honda tech? Thanks in advance.
