break in used motor?
Old Oct 29, 2007 | 02:59 PM
  #21
millertown15's Avatar
Timing Chain Tensioner.
Old Oct 29, 2007 | 05:08 PM
  #22
s2kforlife's Avatar
mine isn't as loud but it kind of sounds similar, is that going to be a problem?
Old Oct 29, 2007 | 07:19 PM
  #23
ShocK's Avatar
Eventually, as far as installation, it take a few minutes. Simple simple simple. Just have to be carful how you pull that pin, thats it.
Old Oct 29, 2007 | 08:47 PM
  #24
MugenS2k615's Avatar
well thats makes me a litto relieved that a few of you guys think its the TCT...ive took one off of the old motor i had, but o man did it go a litto wrong. long story short, i pried it off, pulled it out, n out came the spring n all that litto stuff in it haha....
well i guess thats gona be the first thing im goin to do n hopefulli the last (to rid of the noise) ill wake up in the mornin n go get one n install...
thanks yall, ill let yall know how it goes tomorrow...
Old Oct 30, 2007 | 07:14 AM
  #25
so i went to the dealership to order the TCT...n just for the hell of it, i asked them 2 check it out. so they guy puts his head next to the valve cover n says its coming from there n theyll have to let the car cool down n take it off whichll take several hours...sooo i said ok thank u n reversed my car out.
now i guess ill change it 2moro. i drove it on the interstate n it drives ok, so it SHOULD be the TCT rite? because if it were anything else it shouldnt have drove ok rite? is there a break-in period for the TCT?
Old Oct 30, 2007 | 07:29 AM
  #26
YES its the TCT. Being that the TCT is what keeps the entire engine in sync and you are driving it around, your asking for it. You better hope that thing does not jump time or you'll be installing another motor. FIX it and then drive it. Its the TCT. No break in time needed. Just proper operating temperature.
Old Oct 30, 2007 | 06:19 PM
  #27
ShocK's Avatar
I would have stopped driving it a long time ago, just for assurance purposes. When you replace the TCT be sure you dont pull the pin untill its in the motor and bolted down. pull it sooner and it will fall apart same as your old one. Its hard to get back together too.
Old Oct 30, 2007 | 09:16 PM
  #28
[QUOTE=ShocK,Oct 30 2007, 06:19 PM] I would have stopped driving it
Old Oct 31, 2007 | 08:13 AM
  #29
somone plz answer my quick question, when i put on the new tensioner, is it suppose to sit on the block flat before i pull the pin or does it sit flat after i pull the pin?????
Old Oct 31, 2007 | 08:20 AM
  #30
ShocK's Avatar
Sits on the block flush before you pull the pin, snug is fine on the bolts, maybe just get them torqued after a few days or something, just dont overtighten them or you'll be rethreding the block, not fun. Cant be over 20ft lbs I wouldnt think but I dont know exact torque requirement.
