Buddy Club raccing spec damper........installed :p
Old Feb 4, 2004 | 11:37 AM
ecnay's Avatar
Default Buddy Club raccing spec damper........installed :p
had it installed yesterday, couldnt be happier, i had my eibach pro with stock shock before i replace it with the BC's. the standard setup is perfect, but i will lower my car to no gap between fenders and tires. ride quality is still soft enough for daily driving with 1 adjustibility front and rear. ill try 15 all around and try it on hard turn again tomorrow .
comments, opinion, concern or question is welcome.
-ecnay
Old Feb 4, 2004 | 03:25 PM
GHS2K's Avatar
how much did it cost you if you don't mind telling us? Is the ride softer than stock if adjusted to softest? How low can u go with the BC's? Thanks
Old Feb 4, 2004 | 05:30 PM
GaryRudolph's Avatar
No, the ride is not softer that stock IMO. With stiffer springs it's hard for that to happen. But...
I run them at 4 all around, and that seems decent on the road. But it is more rough. Particularly, on roads that have 1" pot holes.
Old Feb 4, 2004 | 06:06 PM
JL9000's Avatar
[QUOTE]Originally posted by GHS2K
Old Feb 4, 2004 | 07:00 PM
fly_S2K's Avatar
[QUOTE]Originally posted by JL9000
Old Feb 4, 2004 | 07:03 PM
ecnay's Avatar
Old Feb 4, 2004 | 08:03 PM
FYI, when I received my Buddy Clubs:
1) The preload wasn't locked. By this I mean the rings were loose and I had to tighten them together at slightly less than 0 preload.
2) The height was arbitrary. The rings weren't locked, and the height was spinning out of the box. I had to spend time measuring and getting the height accurate. I ended up doing a 20mm (0.8") drop.
Just keep that in mind. I was going to post some info on the Buddy Clubs.. i.e. how many turns equals how many millimeters, etc. How to measure drop.. What is stock height, etc. I'll type that up soon.
Gary
tru
13
Apr 29, 2004 11:30 AM
9000RPM
Aug 20, 2003 12:05 PM
PLYRS 3
Jul 31, 2003 10:29 AM
MKH
17
Apr 29, 2003 07:38 PM
Whitelightning
Jun 20, 2002 09:12 PM
