bumpers
Old Sep 29, 2006 | 10:25 AM
djpeak10's Avatar
Default bumpers
Ok guys I have an AP1 and I know that the front bumper will fit perfect, but is it the same with the back bumper? Because I want to upgrade both but I need them to fit like it is stock, so if anyone can chime in on this that would be great. Thanks
Old Sep 29, 2006 | 10:53 AM
MULDER's Avatar
<--- lost.
Old Sep 29, 2006 | 10:55 AM
beanolo's Avatar
I'm assuming you are referring to AP2 upgraded bumpers. They should fit right on without a prob.
Old Sep 29, 2006 | 11:02 AM
xviper's Avatar
If you are referring to putting AP2 bumpers onto an AP1, they are do-able and have been done by many, but they are NOT a direct bolt on. So no, they will not "fit right on without any problem". Once having done the modifications, they will fit just like if they were from the factory.
An AP2 front bumper requires you to get the AP2 plastic undertray OR make extensions to connect the AP1 undertray with the bottom rear lip of the new bumper. You will also need to use an angle grinder to grind off about an inch from the top corners of the metal bumper beam. Not doing so will result in dimples coming through your new bumper.
https://www.s2ki.com/forums/index.php?showtopic=312278
The AP2 rear bumper sits back a bit from the attachment point of your AP1 bumper and homemade "U" brackets must be made:
https://www.s2ki.com/forums/index.php?showt...0&#entry8071481
Old Sep 29, 2006 | 11:19 AM
djpeak10's Avatar
thanks Dave that is exactly what I was looking for
Old Sep 29, 2006 | 11:42 AM
beanolo's Avatar
Whoops. Sorry bout that. Just saw someone local put it right on..
https://www.s2ki.com/forums/index.ph...&f=18&t=426330
Good luck
Old Sep 29, 2006 | 11:55 AM
xviper's Avatar
Good luck
They obviously didn't post up everything they did. And if he didn't do it all, that undertray is just hanging there. There have been stories of this undertray getting caught in the wind and being pulled down and under the engine. Quite a mess and a huge repair. And the dimples don't show up for a bout 2 weeks.
Old Sep 29, 2006 | 11:56 AM
beanolo's Avatar
That would suck
s2k2fly
Jan 24, 2014 01:39 AM
Kengthao91
Apr 12, 2012 06:39 PM
OneSilverS2k
Apr 26, 2010 11:42 AM
m1sterlaw
Nov 26, 2009 07:17 AM
460cidpower
Feb 28, 2006 07:27 PM
