"Burn" marks on dash from radar detector cord
Old Apr 10, 2009 | 07:49 AM
  #21
s2kdriver80's Avatar
Originally Posted by tekstar,Apr 8 2009, 03:47 PM
have you tried an all purpose cleaner? i would try p21s apc followed by 1z cockpit premium or 303 vinyl protectant. though i have a feeling you won't see any difference since you said you tried vinylex already. definitely try posting in the wash and wax forum for some creative ideas
Is "all purpose cleaner" the name of an actual product? If meant in the generic sense, which product do you recommend? Obviously something that is safe yet effective. What is p21s and 1z?
It isn't something added on top of the vinyl so I don't think anything designed to clean or remove anything will do much. It seems like the textured vinyl surface was worn away by friction, hence the shiny look. But I guess it won't hurt to try the cleaner. Thanks.
Old Apr 10, 2009 | 07:50 AM
  #22
Originally Posted by croftoncustoms,Apr 8 2009, 04:09 PM
i would try a leather conditioner. and claner. and if that doesnt work, find a reallllly good puholstery shop to patch it and put a grain to match to it.
If it gets to the point of having to go to a shop to grain match it, I guess I'll just live with this. Was just wondering if this was a common issue and if there was a quick and easy solution to fix.
Old Apr 10, 2009 | 07:54 AM
  #23
Originally Posted by alSpeed2k,Apr 9 2009, 02:00 AM
Anyhow, when you apply the vinylex do you let the dash dry before placing the wire back onto the dash? As mentioned, it looks like it may be caused by the wire rubbing against the dash. Just try wiping it down with APC and applying your Vinylex again.
Is "APC" the name of an actual product? If meant in the generic sense, which product do you recommend? Obviously something that is safe yet effective.
Do you think the shine is something on top of the vinyl and not the result of wear? If the former, I would imagine an APC might work. If the latter, something needs to be put back into the vinyl professionally.
Old Apr 10, 2009 | 04:45 PM
  #24
gbaker's Avatar
I believe, its possible that using sandpaper or abrasive to put the texture back might not work too well.
I have tried to rough up plastic before (fortunately not my dash) and you end up with a lot of sharp edged scratches and the underside of the edge loses the black color. Sort becomes whitish inside the each scratch. So, I suspect, you will end up with a harder to correct problem.
You might be able to take the gloss off by actually using chemicals to sort of "burn" or add haze to the surface. But I have no clue as to what chemical could be used without long term detrimental effects.
I would take it to a shop, upholstery or similar or Honda Dealer. It seems if you do something yourself to repair and it makes things worse the cost to fix could go up exponentially. It might not cost too much to see a Pro. since it seems like a small effective area.
Again good luck.
Old Apr 10, 2009 | 11:28 PM
  #25
alSpeed2k's Avatar
All Purpose Cleaner is exactly that. It's not a specific brand. A common one that is used is Meguiars: https://www.s2ki.com/forums/index.ph...&f=15&t=411106
Just give it a good scrub using a nice Microfiber towel, then apply your Vinylex (I use 303).
Old Apr 11, 2009 | 07:55 AM
  #26
Thanks man. Even if that doesn't solve the dash burn issue, I think I'm gonna try this product out, for the cleaning qualities if anything.
If I want to clean vinyl surfaces like the dash and door panels, I just mist the diluted solution from a spray bottle and use a polishing motion with an MF rag, right? Do I need to rinse with pure water afterwards, or is that not necessary?
I have a pretty dirty interior and if I were to go ahead and clean right now, I would
1. wipe everything down in the interior with damp water to get rid of the grime and dust,
2. use the APC solution,
3. wipe down with water again,
4. follow up with Vinylex.
Would these be the proper steps? Do I need to do #3, or heck, even #1?
Old Apr 11, 2009 | 09:02 PM
  #27
So #1 and #3 not necessary? I could have sworn someone made such a post.
Old Apr 11, 2009 | 10:50 PM
  #28
alSpeed2k's Avatar
#1 depends on how dusty the interior is. #3 not necessary unless you over do #2.
macdaddies911
Apr 15, 2010 04:37 AM
s2kdriver80
Apr 10, 2009 07:40 AM
Monty
Feb 26, 2005 03:46 AM
JamieS2K
Jun 3, 2003 04:29 AM
JamesM
Feb 21, 2002 04:52 AM
