Buying a s2000 that hasn't been driven in 2 years
Hi all,
Wanted to get your opinions. I have an opportunity to buy an S with a blown engine. The car has been sitting in a lot for 2 years without being driven. I can get a used engine for about 2500 or so.
The rest of the car is in decent condition. What are some other things I should look for? I'd probably have to get new tires, flush all fluids, anything else?
Also, how much do you think I should I should pay for it? It's a 2003 with about 70k on the chassis.
If it all works out, this would be my 3rd S. it'd be nice to get back into one.
Thanks!
Thanks!
Battery
Brake, clutch, transmission, diff fluids
Engine oil
Coolant flush
Inspect for suspension damage
Water seals (use shinetsu grease)
Check brake pads
Tires
Check exhaust for rust
Check parking brake cable
Check brake piston boots
Check axle boots
Engine oil
Coolant flush
Check brake pads
Tires
Check axle boots
My S2k is an 01. From the car fax that I understood that my car were sitting almost 5 years. Seems to me that my car was crash and put it away. I pick-up in perfect condition from a owner. I have put it 10,000 miles in two years with 0 problems. When I say 0 problems I mean 0 problems. Obviously I change old the fluids on the car. I also tracket a lot.
If the price is good go for it. S2k are pretty realibles.
Elistan
May 5, 2005 10:27 AM
