Buying s2k
Old May 2, 2008 | 08:15 AM
s2k_man's Avatar
Default Buying s2k
Hey, guys I am going to look at an 00 s2k with 28k miles. I know i should look for Curb rash,Oil levels/leaks, 1-2 shift grind, Brake fluid. Is there anything eles I should look for?
Also is a compression test needed since it only has 28k miles?
Old May 2, 2008 | 08:18 AM
3ngin33r1's Avatar
You should look by using the search, this is discussed AT LEAST 3 times a week.
Old May 2, 2008 | 08:55 AM
ebbai's Avatar
you should check for clutch buzz as well.
there was a TSB on it but if the owner haven't fix it I doubt the dealers would fix it under warranty.(if it still has warranty).
I'm pretty sure most MY00 had this issue.
the noise isn't present when the car is new but after a while it appears.
with 28,000 miles, I don't know if the car has the buzz or not yet..
Old May 2, 2008 | 02:43 PM
s2k_man's Avatar
Well i went to check out the car and it already sold! : /
So i went to Crown honda and test drove a silver s2k with 68k miles it was a 2001. It grinded a little when shifting into 2nd. Why is the little grind in 2nd a big deal, or is it a big deal?
Old May 2, 2008 | 02:46 PM
D_Spec's Avatar
I would also check the soft top real good. I bought mine and it looked good at first.
then it rained real hard and my car was full of water.
Old May 2, 2008 | 03:02 PM
s2k_man's Avatar
Yea im not buying the car there. GET THIS they have a 2001 s2k for 17,999. The car has 68,000 miles and a SMALL rip which will get bigger on the top. There is also a slight grind in 2nd. The guy lowered his price to 16,999 and says im getting a deal.
06gpws2k
Jul 13, 2010 03:08 AM
HottS2KinNJ
Nov 6, 2008 07:21 AM
sphincter
Jun 3, 2007 06:28 AM
radek
Dec 18, 2003 03:42 PM
yidal8
Dec 23, 2000 10:09 PM
