A/C not as cold as it used to be
Old May 9, 2007 | 11:46 AM
Allstar's Avatar
Default A/C not as cold as it used to be
I feel that my A/C in the s2k isnt as cold as it used to be... or maybe A/Cs are weak in general for the s2k? I've only had the car for 5 months now and it seems as if my A/C can't blast cold air anymore.
when the AC is on, it sorta makes a huge sucking noise at times (perhaps its my KN FIPK not sure).
my MPG has been dipping too, is this indicative of any problems? the car is 05 and only has 12k miles.
Old May 9, 2007 | 12:04 PM
neveronlines2k's Avatar
My AC is pretty strong (gets cold), but I very rarely use it.
You probably just need freon (dont know the spelling) because it is getting low. To make it cold again you will need to recharge it (refill). It sounds easy, but is actually expensive (for what they are doing)
Old May 9, 2007 | 12:21 PM
sparrow's Avatar
global warming
Old May 9, 2007 | 12:56 PM
nightcrawler7188's Avatar
you sure the A\C light is on? and maybe check cabin air filter?
iam7head's Avatar
the better question is why is it low on freon in the first place, it's a sealed system to begin with, unless you have a malfunction or broken link in the system the freon shouldn't just "gone" or "get used up"
take it to the pro, you can overcharge and burnt the compressor if you have no idea what you doing.
Old May 9, 2007 | 12:57 PM
iam7head's Avatar
Originally Posted by sparrow,May 9 2007, 12:21 PM
global warming
here comes to crappy answer club
Old May 9, 2007 | 01:06 PM
stooken's Avatar
Go repump the AC. It's like $50-$70.
Old May 9, 2007 | 01:08 PM
Reborn56's Avatar
Originally Posted by sparrow,May 9 2007, 03:21 PM
global warming
Worried about global warming? Carbondioxide is the number one green house gas? Well, humans exhale Carbondioxide. So if you want to aid in the solution for global warming, plant a tree and then drop dead!
Couldnt resist.
Old May 9, 2007 | 01:10 PM
Reborn56's Avatar
Nah but seriously Refrigerant(freon) doesnt just get used up there is a leak somewhere in your system. If in fact you are low on refrigerant.
If thats not the case then DEF look at your cabin filter if its plugged solid your evap coil is freezing up due to lack of air and not producing cool air inside your car.
Marcus
Old May 9, 2007 | 01:12 PM
my01s2k's Avatar
is your ac only gets cold when you are moving? mind seems to be warm when am sitting/waiting at a stop light. when the car is moving it gets cold again. anyone else have the same issue?
