CAI vs Cool plate
Old Sep 17, 2007 | 09:02 PM
albe's Avatar
Default CAI vs Cool plate
which one is better to use?
Old Sep 17, 2007 | 09:10 PM
nightcrawler7188's Avatar
a CAI goes down below the beltline of the car, and the cooling plate goes over the radiator. i think if you use a CAI, the cooling plate wouldn't do much. if you got a short ram intake then the cooling plate would help
Old Sep 17, 2007 | 10:46 PM
GyozA's Avatar
Get a duct... or a comptech/k&n intake. No major gains, but the sound is wonderful.
Old Sep 19, 2007 | 09:23 PM
s2kSEOUL's Avatar
i have cai. seems to slow down throttle response a smidge. sounds great and helped with heat soak. reportedly a few hp and tq gain. friend with tuning shop recommeded stock airbox with duct.
Old Sep 26, 2007 | 11:11 AM
EddieAtATL's Avatar
duct = snorkel ?
Old Sep 26, 2007 | 11:22 AM
DeeDubya's Avatar
Seibon CF - Remove OEM deflector and bolt it on - too easy and a surefire way to get cool air into your factory box. Obviously won't increase intake sound, if that's what you want.
Old Sep 26, 2007 | 12:51 PM
^^removing the OEM deflector is DEFINITELY not that easy.
Old Sep 26, 2007 | 01:36 PM
DeeDubya's Avatar
You're right, the front fasteners inside the bumper are hard to get to. But once you've found them they are relatively easy to remove.
I've seen some just cut out the deflector on the passenger side to allow more air flow up into the intake, but the cooling plate is designed to seal the area above the radiator so it makes the deflector more or less worthless.
Old Sep 26, 2007 | 07:17 PM
Saki GT's Avatar
Don't remove the OEM deflector, just cut out a panel on the passenger side. The stock plate keeps air pressure high in front of the radiator and is part of the fluid dynamics of the engine bay.
Old Sep 26, 2007 | 07:22 PM
^^SH*T! really? i took mine off when i put the cooling plate in. now i sold the cooling plate and have been without the air guide for like 3 months...
