calipers clicking
Old Jul 19, 2005 | 09:53 AM
Icemn2003's Avatar
Default calipers clicking
Hey all,
Whenever I go from reverse to forward, or even come from a stop to accelerating, the calipers click/creak, apparently from the shoe moving inside the caliper.
The guy service guy at the dealership said that there's nothing they can do without making the brakes squeak, but i recall another service guy telling me it's an easy problem to fix, just lubricating the caliper?
Has anyone else had this problem?
J
Old Jul 19, 2005 | 10:29 AM
CaptainMike's Avatar
It may not be your brakes/calipers, but rather your rear hub. There is a TSB somewhere I think, and some info in UTH. If "Search" wasn't down I could have it for you in a second. But look around UTH, there's a recent 'Clicking' thread there I think.
Old Jul 19, 2005 | 10:53 AM
steven975's Avatar
I had a similar problem. the problem in my case was that the area between the wheel and hub was dirty, causing some shifting.
other causes are the axle nut being too loose...with yours being a 2001 I think this is likely. Honda updated the torque specs for that bolt due to this problem.
Old Jul 19, 2005 | 11:17 AM
flatOVERcrest's Avatar
I have a 05 with 380 miles on the odo and have the same noise from the front calipers/pads. Nothing to worry about, just a bit annoying when it happens..
Old Jul 19, 2005 | 01:47 PM
Chosun's Avatar
I had it too, but then it went away on it's own. :-D
Old Jul 19, 2005 | 07:08 PM
Icemn2003's Avatar
I'm not worried about it, it's just quite annoying and it SOUNDs like a bad thing, though i know it's not.
I know it's the calipers though, because when it first started the service tech reproduced the noise by pressing on the caliper with his hands.
Old Jul 19, 2005 | 07:54 PM
jwa4378's Avatar
I had the EXACT same problem. Dealer replaced rear calipers under warranty (Certified warranty). Now it only clicks occasionally when engaging the brakes. Taking it in tomorrow at 2 for them to look at it again. I already tightened the rear hub nuts. I am thinking it might be CV joint. I will post when I get it back from the dealer.
john
tony2k
May 12, 2010 08:17 AM
sharksfinn
Feb 14, 2010 10:26 AM
sharksfinn
Nov 1, 2009 02:54 AM
pistonbroke
Oct 27, 2008 06:49 AM
minboost
Dec 12, 2004 02:34 PM
