camber kit?
Old May 13, 2006 | 08:20 PM
sinner's Avatar
Default camber kit?
I'm on H&R coilovers and 18"works. Will I eat up my tires if I don't?
Old May 13, 2006 | 08:26 PM
RED MX5's Avatar
You need to get the car aligned after lowering. With a 1" or 1-1/2" drop a good alignment shop can get the car back to factory specs without any kind of kit.
How much is your car lowered?
Old May 13, 2006 | 08:45 PM
sinner's Avatar
It was lowered when the coilovers went on, but now that the 18's on, it needs to come down another half inch. Hopefully there'll be no fender gap at all, so fairly low.
Old May 13, 2006 | 08:53 PM
Dark_Sub_Rosa's Avatar
car is adjustable from Honda, you don't need a kit.
Old May 13, 2006 | 09:00 PM
RED MX5's Avatar
I doubt you're low enough to have problems achieving proper camber. Have the car aligned at a good shop, and don't worry about it unless they can't get the camber where you want it.
I'm dropped an inch in the back and a little over an inch in the front, and I have adjustment to spare (and I'm running UK specs, which call for greater negative camber). You really have to slam the car before camber adjustment becomes a problem.
Have you had the car aligned since it was dropped?
Old May 13, 2006 | 09:06 PM
RED MX5's Avatar
There are kits that alter the range of camber adjustment, though I doubt he needs anything more than a good alignment.
S2000_916
Nov 3, 2015 03:50 AM
pputkowski
Jan 21, 2009 12:38 PM
irev9k
Feb 24, 2008 07:10 PM
vspc2nr
Aug 11, 2007 08:47 AM
kwokdezz
Nov 10, 2004 01:26 PM
