Camber Kit Install?
Old Jun 29, 2021 | 04:33 AM
TheDailyS2K's Avatar
Default Camber Kit Install?
I installed camber kit install and touched up the rear coils to make it a little bit more negative to clear tire rubbing, after I completed the install I noticed my car likes to shift to the right more than the going straight or left, I know I need an alignment but want feedback because I may have done an error or I just need a proper alignment?
Old Jun 29, 2021 | 08:20 AM
B serious's Avatar
Start by checking your install. Nobody here is gonna know if you did it correctly.
Did you do it correctly?
Up to now...only you know what parts you installed and what you've done.
You 100% for sure need an alignment anyway.
So...if nothing is loose or broken or installed incorrectly, get an alignment.
Old Jun 29, 2021 | 02:27 PM
I have a question, I got the alignment done today but the shop recommended me to adjust my ride height, will I need another alignment? Or it will be fine because I just got one today. The height adjustment they recommended me was not major but to make it lower in the front and raise it in the rears.
Old Jun 30, 2021 | 03:31 AM
Samba's Avatar
Yes, if you want your alignment to be correct, adjusting ride height will change the alignment.
Old Jun 30, 2021 | 07:18 AM
B serious's Avatar
Why did they recommend it?
And yes, you should get a new alignment afterwards.
beaudin223
Jun 30, 2014 09:54 PM
Trigun
Feb 19, 2008 06:23 PM
Tee-Dub
Oct 1, 2007 07:27 PM
geovong
Sep 28, 2006 01:13 PM
bigal1
Jul 27, 2004 01:07 PM
