Can my top be fixed
Old Sep 8, 2003 | 10:51 AM
aggie's Avatar
Default Can my top be fixed
There is a slit about 1/2" x 1/2" at a 90 degree angle. It is located over the drivers head. Can this be repaired or is a new top necessary?
Old Sep 8, 2003 | 10:54 AM
cyber_x's Avatar
aggie,
My guess is you'll need a new top. My top was damaged in a similar manner some time ago, and I was told that it can't be repaired.
Old Sep 8, 2003 | 11:31 AM
3ngin33r1's Avatar
You can repair anything. What it looks like is a different story.
If you don't care about how it looks, go to a marine supplier and pickup some sail repair stuff.
Old Sep 8, 2003 | 12:10 PM
S2KYSK's Avatar
Of course they will say it needs to be replaced. More $$$ for them that way. If the $$$ is coming out of my pocket I'll check with upholstery first to see if they could fix it without being too noticeable.
Old Sep 8, 2003 | 12:28 PM
aggie's Avatar
To be more specific, a body shop damaged the top and they 'seem' to be taking responsibility. One Honda dealer I called said a quality repair is better than a new top, because a bunch of other things can get screwed up. Two local soft top repair/replace shops said the top must be replaced, since a repair will eventually tear/leak later on. This sucks!
Old Sep 8, 2003 | 12:37 PM
cyber_x's Avatar
aggie,
For what it's worth, when my top was damaged, it was also at the hands of a POS body shop. They ripped it along the side seams...the resulting slit was maybe 1" long. I'm sure it's of little consolation, but you're not alone...
In my situation, I took the car to several upholstery shops, and they all said the top should be replaced. I don't believe money was a motivation for those shops, because they all recommended I get it replaced by the dealer...none of them wanted to accept the responsibility of attempting to repair the top. In my case, the unanimous advice was to replace the top.
Old Sep 8, 2003 | 01:15 PM
S2KYSK's Avatar
Shoot, in that case ofcourse. You need to replace it with brand new top. If you want I think you could get either blue or beige as well.
Old Sep 8, 2003 | 01:42 PM
3ngin33r1's Avatar
I don't know about anyone else, but that blue top is just kind of fugly (no insult intended for anyone that may have it).
Old Sep 8, 2003 | 03:14 PM
JsnS2k's Avatar
"beige"
There is a beige top?? OEM?
Old Sep 8, 2003 | 03:34 PM
Ravenwerk's Avatar
Beige top on a Sebring with a black interior. Oh yeah, that'll work.
