car died on street
Old Mar 29, 2009 | 06:06 PM
CleanwestsideAP's Avatar
Default car died on street
Just bought a 2001 with 22k miles on it.
I was driving home from work today and the car started sputtering and wouldn't rev past 4.5k and then the car started losing power and finally died and I had to coast it to the side of the road.
Now I have been trying to start the car and it wont start. The radio and lights still work. I am going to have it towed to Honda Dealership tomorrow morning
Can anyone possibly help diagnose the problem>?
Car was driving fine before this happened.
Old Mar 29, 2009 | 06:12 PM
NDAZONE's Avatar
I'm no mechanic but maybe its your Mass Air Flow sensor.
Old Mar 29, 2009 | 06:24 PM
CKit's Avatar
What did the sputtering sound like?
Hopefully it's just a MAP sensor.
But I've never heard of a MAP sensor just completely giving out when driving.
Hopefully the car wasn't abused in any way or had past cracked retainers and dropped a valve.
Any CELs come up? Any heinous grinding sounds?
Old Mar 29, 2009 | 07:41 PM
The car sort of wouldn't rev past 3-4 k all of the sudden and then the car started choking in a way....
After this I had to pull over because the car turned off.
Just before the car died the check engine light flashed 2 times and the car shut off and would not start after that. The lights and radio and everything still work but car wont start.
No grinding sounds.
The car is getting towed tomorrow to the dealership. I hope it is not anything major. Any other possible ideas?
Old Mar 29, 2009 | 07:43 PM
Saki GT's Avatar
Have you tried to start it again? Fuel starvation might be an issue?
Old Mar 29, 2009 | 07:47 PM
i tried starting the car once 30 minutes after this happend and I just went back out to try and start the car again 2 hours after the first re-start attempt.
I dont know what else I can do at this time.
Old Mar 29, 2009 | 07:49 PM
DFWs2k's Avatar
do you have gas in your car?
Old Mar 29, 2009 | 07:50 PM
i had to go to gas station and put gas in with a gas can. so it should have at least 3/4 of a gallon. is this enough?
Old Mar 29, 2009 | 08:10 PM
CKit's Avatar
You ran it dry?!!!!!
Old Mar 29, 2009 | 08:27 PM
jnxdluck's Avatar
3/4 of a gallon of gas might not be enough if it was completely empty. After adding the 3/4 gallon of gas, was the car parked on an angle? It could be that the 3/4 gallon of gas was sitting low in the tank.
