Car feels unstable going over sewers/dips/ect
Old May 5, 2007 | 09:57 AM
gtg749m's Avatar
Default Car feels unstable going over sewers/dips/ect
Whenever i go over dips in roads, or the 'sewers' that dip into the road a bit, or anything where the pavement may have any kind of dip my S feels like its unstable.
my tire pressure is at 32 psi all around(hankook rs2's if that matters). stock everything.
does anyone else experience this or is there a way to fix this?
Old May 5, 2007 | 10:24 AM
negcamber's Avatar
Is it an AP1? If so, this is a known characteristic called bump steer. There are a couple different kits available to help correct the problem, sometimes called BSK (bumpsteer kit).
Megan has one of the more affordable versions:
http://www.meganracing.com/products/produc...d=576&catid=108
For a good thread covering all the BSKs available, read:
https://www.s2ki.com/forums/index.php?showtopic=444819
Old May 5, 2007 | 03:31 PM
gtg749m's Avatar
would an alignment help? i think the last time i got one done was aobut 1 yr and 5 months ago.
Old May 5, 2007 | 04:28 PM
sahtt's Avatar
It would help if your car is out of alignment. If you hit a curb etc. since your last alignment it might be a good idea.
Old May 5, 2007 | 04:33 PM
wanabe's Avatar
worth checking....
thats what i was gonna post before i saw your question!
Old May 5, 2007 | 05:29 PM
AlwaysTopless's Avatar
Alignments usually go out within 5-6 Months or 5-6K Miles, even quicker if you have after-market suspension regardless of the situation. You should have it checked, and try running a little less positive caster. That should reduce bump steer on stock suspension a little. But keep in mind that you may lose some steering feel if you do that.
BTW is it an AP1? What MY?
Old May 5, 2007 | 05:52 PM
wanabe's Avatar
ap2 = 2004+
Old May 5, 2007 | 05:57 PM
gomarlins3's Avatar
I agree with the alignment check that was suggested above.
Old May 5, 2007 | 06:12 PM
dead-bird's Avatar
It's a long shot but check for spring spacers...
Some times they don't get all of them.
Old May 5, 2007 | 11:04 PM
gtg749m's Avatar
ap1 yes
