Catalytic convertor
Old Sep 2, 2006 | 05:51 PM
xviper's Avatar
Originally Posted by djpeak10,Sep 2 2006, 07:44 PM
so xviper have you had any problems like this, and am I going to be having to replace a cat an 02 sensor every 6 months or what
(Touch wood.) I have had absolutely no problems with the cat or the O2 sensor after over 3.5 years of supercharger duty. Keep in mind that my Vortech is stock and not modded to produce more boost. I believe both kits (CT and VT) were designed to run perfectly reliably on an otherwise stock S2000 so long as you don't begin to mod the kits.
Old Sep 2, 2006 | 06:10 PM
daniel_ap1's Avatar
Originally Posted by xviper,Sep 2 2006, 05:38 PM
Are you sure about this or just making an assumption of some kind? A supercharger will double, triple and possibly even quadruple the work load of the cat. An "unauthorized" supercharger like the Vortech will more than likely void all aspects of the factory warranty and definately void all aspects of any extended warranty. I think you're dreaming if you consider a supercharger won't void a warranty.
The only "authorized" supercharger is the Comptech and only if installed at a Comptech authorized dealer.
BTW, I see you've got the AEM EMS. Any bets if you have some kind of melt down in your powertrain that it will void that part of your warranty? Oh and wait till they find out all that other stuff you've got on your car.
actually we just put a cat on a supercharged s2k at work "i'm a tech at crownhonda" we dont care t but if they are having to use a extended aftermarket warrnty then it will not be coverd but seeing how it is covered under the emissions warranty it should not be denied.
Thats how it is at the dealership i work at atleast
and yes if i have some type of melt down i will put it back to stock bitch a little to honda and get it good will warranty the work
Old Sep 2, 2006 | 06:22 PM
xviper's Avatar
I think your dealership is the exception rather than the rule. Almost all car manufacturers will not allow their dealership network to accept warranty claims on a car that is modified with a supercharger or a turbo (when they didn't come with one out of the box).
One has to ask why turbo S2000s and Vortech S2000s are not smog certifiable. The cats just can't handle the extra emissions.
Old Sep 2, 2006 | 06:28 PM
daniel_ap1's Avatar
well it would be worth his time for him to check at a dealership to see if they would cover it
the s2k that we put a cat had the same problem as what he is having with his
also the flow honda dealership in winston salem nc has replaced a motor on a s2000 that the owner bought and had the dealership install a supercharger under warranty
you really will be surprised at all the stuff you can get away with if you own a honda i do more warranty work then anything. most of the time if they will not cover they can give you a number to where you can call and talk to honda about it. Just bitch enough and they will usually give it to you
Old Sep 2, 2006 | 06:40 PM
xviper's Avatar
There are always ongoing current threads from people who are being denied warranty work from their Honda dealers. You would be of great help in advising these people.
Old Sep 2, 2006 | 06:58 PM
daniel_ap1's Avatar
In this situation there is good chance he should beable to get his factory emissions warranty to cover it. Lets say though he was still in warranty and came in with a motor problem it deff wouldnt be covered unless your friends with a advisor or something. Under factory warranty or emissions warranty no one comes out to inspect the vehicle they may call for the old part to be sent back but no comes out.
I guess as you said its up to your dealership but it never hurts to ask
Once you get into extended warranties we at the dealership do not make the call. The company that your extended warranty is through will send out someone to inspect the car or will have the technician or service advisor tell them if any modifactions are done to the vehicle
so a word of advice for anyone with a extended warranty is to take the car all the way back to stock if you want to get something covered even if your running supercharger and going in for a window problem if later your rear end goes out they may have notes on the computer or photos of your supercharger on file and use that to deny a later claim. I've seen it happen to a guy with a nitrous line that wasnt run right on a s2k and rubbed a hole in a axle boot. He came back in later with no nitrous bottle but we had pics of the setup stored and was denied.
something as simple as a intake will basically get all motor and drive coverages denied witch is basically BS but thats how the system works
Old Sep 2, 2006 | 07:13 PM
djpeak10's Avatar
what do you mean It has a carb number and i just passed smog a month ago
Old Sep 2, 2006 | 07:42 PM
xviper's Avatar
What is "It"? All turbos? Or Vortech?
Old Sep 2, 2006 | 07:47 PM
djpeak10's Avatar
the votech supercharger kit which i have
Old Sep 2, 2006 | 08:25 PM
xviper's Avatar
OK, I had heard they were working on getting the certification. I didn't realize it had been done. Still, I don't believe any Turbo kit has it. The point is, it's tough on the cat when you push that much exhaust through it and that's what contributes to it being difficult to certify. The stock supercharger kits obviously are within the performance parameters of the cat, but I'm betting that they get quite a work-out anyway. Mod the kit and push up the boost and I can guess that the cat's lifespan will be affected. How much? Hard to say.
