cause of crease in rear window?
Old May 3, 2001 | 01:22 PM
shingles's Avatar
Ok, I got to looking at the car yesterday and realized that the creases(two, 1 near top and 1 near bottom) were more than likely caused by the brace. So if that's the case, what's a "miata roll" going to do for that? nothing. I had always thought that it was being folded in half. So my question now is...would a thick padded something or another, like the Muz Mat for example, be better? I tried the roll, doesn't work, I am now using a bath towel folded in half, doesn't work too well... any other ideas?
-Shing
Old May 3, 2001 | 01:42 PM
lvs2k's Avatar
In order to minimze/eliminate creasing, I suggest you use a terrycloth bath towel. First, lay it across the window. Next, tuck the towel under the top where it overlaps the window at the top and either side of the window. Now it will be held in place when you lower the top and will prevent the window from touching (and scratching) itself when it folds in half. The towel also cushions the effect the braces have on the rear window. Any creasing that does occur will smooth out the next time you raise the top and the weather is warm.
rockmore
Jan 29, 2006 05:09 PM
ek5686
Aug 7, 2005 08:27 PM
cbb
Aug 5, 2002 04:55 PM
cabinfever
Oct 20, 2001 07:57 PM
Zeke
Mar 22, 2001 11:41 PM
