CDV seems like a really bad idea
Old Jun 21, 2008 | 10:10 PM
Project22a's Avatar
Originally Posted by Shazzam,Jun 21 2008, 05:37 PM
burned up the , pressure plate and bearing at about 5000 miles.
He had to be abusing the hell out of the car to do that.
Old Jun 22, 2008 | 01:07 AM
xedk's Avatar
i'd have to agree... it takes some effort to destroy pieces that are supposed to last a lot longer than that.
Old Jun 22, 2008 | 07:32 AM
boyguan's Avatar
i have an ap2.
i removed the cdv after a few slips at the track.
the clutch still seems to slip now even without it.
i will be upgrading the PP when it is time to do the clutch. i hope that this will fix the problem
Old Jun 22, 2008 | 12:22 PM
JHooby's Avatar
[QUOTE=boyguan,Jun 22 2008, 07:32 AM] i have an ap2.
Old Jun 22, 2008 | 02:05 PM
skier219's Avatar
The valve is only part of the problem, in that it could potentially allow you to get the engine RPMs outrunning the transmission before the clutch is fully engaged. That can be avoided by learning to work with the valve rather than fighting it. If the paltry delay time is a problem, that's another story -- who are you, superman? ;-) But the major factor has to be the pressure plate. Ultimately that is what determines the final engagement.
Old Jun 23, 2008 | 07:10 AM
ddess's Avatar
I have taken out the CDV on my 06. It definitely helps. The PP is a whole other issue. There is still slippage under hard shifts from 2nd to 3rd. I did the CDV because it was easier and much cheaper than replacing the PP. I will upgrade the PP when the clutch needs replacement.
Old Jun 23, 2008 | 07:39 AM
TKim103's Avatar
i took off my CDV. Best thing I've done so far
Old Jun 23, 2008 | 08:02 AM
smurf2k's Avatar
CDV is annoying, even when im not trying to drive hard
Old Jun 23, 2008 | 08:16 AM
Saki GT's Avatar
Originally Posted by JHooby,Jun 22 2008, 04:22 PM
thats real weird.
i had an 04 clutch on my car for about 10k miles..
no slippage at all.
Of course you don't have any slip - you have an AP1 flywheel.
Old Jun 23, 2008 | 10:42 AM
JHooby's Avatar
ah true. didnt think of that one but heavier flywheel = clutch slippage?
