CEL today, help
Old Jul 3, 2007 | 12:39 PM
MikeyCB's Avatar
Are you running a stock intake?
Old Jul 3, 2007 | 12:40 PM
Stealth_SUX_'s Avatar
Its stock except for K&N filter.. Not cold air just the filter
Old Jul 3, 2007 | 02:17 PM
RedChili's Avatar
P1519 Idle Air Control Valve Circuit Failure.
It's the solenoid that controls your engine idle speed. You need to get it checked out to see if it's just a loose connection or you need a new part.
Old Jul 3, 2007 | 03:35 PM
Where is it located at... and what does it look like..
Old Jul 3, 2007 | 06:02 PM
Does this make sense, I unclipped and reclipped the IAC valve wires and reset the ecu and it worked fine...
It seems to easy, am I just bying time before something else happens or what..
Old Jul 3, 2007 | 06:56 PM
RedChili's Avatar
It's just an intermitent failure, and system is OK at this time. If the code comes back then you probably will need a new part. A bad IAC valve would normally just cause idling problems.
XBMAX
Nov 23, 2012 02:28 PM
Ap2S2000
Mar 24, 2010 10:26 PM
doducks
Oct 22, 2009 05:29 AM
Sabre
Sep 13, 2008 05:59 PM
bballplaya210
Aug 30, 2007 04:14 PM
